astolleis
If it makes you feel any better, you're better off without this update. The DTE shown before this update was pretty reliable. Now it isn't.
This is my DTE after charging last night.
This is my DTE after driving my 50 mile commute.
I'm using the same percentage of battery, but the DTE is an unachievable number. I would attach my EV drive history, but that never reset last night. Another software issue Ford has yet to address. But my mi/kWh was around 1.7 driving home last night.
I drive this same commute every day. When my DTE was showing 195-ish at 90% before this update it was correct. Now we are being misled about our range, probably to appease people that see a small number and think there is something wrong. Now people are going to complain when they can't go as far as the truck says.
I would rather have an uncomfortable truth than be misled.
I always appreciate your perspective and sadly I now will have to keep on my DTE's new version. I was uncomfortable before now seems my anxiety will be greater now.
My truck finally updated successfully after about 1 hour of driving around town, then home. At home. I plugged into FCSP, turned off PAAK and put phone in house. Used a fob to start the truck and manually start the update. I stopped the truck and locked the doors. The countdown started to update. At 10 minutes, i still hadn't got the email you failed. I walked out and looked in with no key so the "welcome" did not occur. The Software update screen was up and the truck was making some weird noises. I did see the truck reboot and everything went black. Phone now says updated to the new version.
I got an email from ford about a new layout of screens on Sync4/4A. Is that is what is coming in 4.1.1?
