Jlarbeypro
Correct.So, you're referencing the white lights on the sides of the headlights? No lightbar?
Keep us posted, let us know if you get it fixed. I'm installing the Lightbar on my Pro when I have time. I will be fiddling around with a bunch of these settings to try and get it to turn on.Correct.
Ok. I basically started over and I got the lights to come back on, but the green DRL (parking lights) icon isn’t there anymore during the day. The brightness from what I can tell never changed either however those lights are pretty wimpy anyways so no even worth trying in my opinion.Keep us posted, let us know if you get it fixed. I'm installing the Lightbar on my Pro when I have time. I will be fiddling around with a bunch of these settings to try and get it to turn on.
I have a lightbar, not installed yet.Ok. I basically started over and I got the lights to come back on, but the green DRL (parking lights) icon isn’t there anymore during the day. The brightness from what I can tell never changed either however those lights are pretty wimpy anyways so no even worth trying in my opinion.
keep me posted if # 1 you get a light bar and #2 how you programmed it. A guy on Facebook lightning group installed one, but he can’t get it to turn on. Says there is no power to the plug that already exists beyond the grille. Someone mentioned it will need to be “code added” not adjusted on forscan, since ours is a pro….
only dealer can do it but probably wouldn’t
Do all lightning trims come with all the hardware to enable adaptive cruise control (LIDAR, etc) even if it wasn’t a factory option or are you planning on adding all that and enabling it thru Forscan?Out of curiosity, is the CCM module showing up in Forscan for anyone with a lightning? If so, what is it called? I am looking to enable adaptive cruise control.
That is what I am trying to determine. Others have added a CCM then enabled ACC on ICE models, but I don't see that part from Ford. I only see a "Speed Sensor".Do all lightning trims come with all the hardware to enable adaptive cruise control (LIDAR, etc) even if it wasn’t a factory option or are you planning on adding all that and enabling it thru Forscan?
I don't see any changes in the sticky - I think you added IPC settings to the wrong section (the auto-window stuff). I looked at the ICE thread and added the settings, and now I have the headlight with "A" in it. I'll see how it acts later.
I did notice that the HCM is now throwing DTC for "General Checksum Failure" which is lighting the MIL.
Clearing DTC's doesn't work - it just comes right back...Code:Code: U3000 - Control Module Additional Fault Symptom: - General Checksum Failure Status: - DTC Present at Time of Request - Malfunction Indicator Lamp is On for this DTC Module: Headlamp Control Module
Hey @vandy1981, I did some more experimenting tonight and found the working glare-free settings from scratch.
See https://www.f150lightningforum.com/forum/threads/lightning-forscan-hcm-spreadsheet.11807/post-248344 for the post.
Here is the proper HCM recipe for a new truck:
734-01-02 xxxx x2xx xx-- (CAF ADB_GfHB)
734-03-02 xxxx xxxx x1-- (ADBDBL ADB/DBL Combined)
734-11-01 0735 89
Then you have to check to make sure there aren't any checksum DTC's set for the HCM - that will prevent glare-free and bendy beams from working.
Awesome - hopefully @vandy1981 can update the first post here shortly!After updating this value on my truck the error on the HCM went away. Now I need to find sometime without rain to drive the truck and test it.
Awesome, I got my scanner this week so I think I will try with my XLT this weekend.I can confirm that the 1801 is needed to make the glare free work. Everything worked as it should tonight. Much better than auto high beam.
I've updated that value in the sticky to:Small update. I found a vin from our reservation and orders thread that was from Canada with a base XLT. Pulling there as built data I compared to what I had above. The only difference is the below value. The “1” in the 1801 is for zone lighting which shouldn’t apply since I don’t have it.
HCM | 734-03-02 | xxxx | xxx1 | x1-- |
