Tony Burgh
- First Name
- Tony
- Sep 28, 2021
- Western Pennsylvania
- 22 Lariat ER
- Occupation
- Retired
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.So today after returning home, I opened my front trunk using the button under the hood and it operated just fine. I removed some stuff and then went to close it and after pushing the button, nothing happened. I thought that was very weird, so then I went to push the button on the fob. Nothing. I then went into the cab and pushed the button on the dash. Nothing. I thought maybe even though it'd been at most 2 minutes since opening the trunk that it had "timed out" and had to be manually cycled like when the frunk is left open for more than 30 minutes. I slowly pushed it down, but when I got to the latch, the pull down motor did not engage. This is when I realized something was very wrong.
First thing that came to mind was a blown fuse so after looking through the manual, I learned there was a fuse in the under hood fuse box and in the body control fuse box in the cab.
I checked both for continuity with a multimeter and removed them for a visual inspection. They were fine.
I then thought maybe somehow the emergency release had been pressed, but even after manually cycling the hood down and pushing it closed manually, it wouldn't function. I had to use the emergency release cable to open the hood.
The last thing I tried was to disconnect the 12V battery to see if maybe it would reset a module that had faulted out for some reason. This didn't change anything either, unfortunately.
The only clue I have is the very quiet sound of a relay clicking near the underhood fuse box when the button is pushed, but nothing else happens.
I already have an appointment at the dealer this Friday for something else so I'll be bringing it in, but anyone have any tips, ideas or theories??
This is just so frustrating as it was perfectly functional one second and dead the next!
Yeah, I feel like mine is made of leather and I can't get it wet. I've got the light bar water intrusion issue already, hoping I don't end up with the dead frunk too.With the kind of weather we get here, the frunk issue has me worried. If this is a big one, I hope a recall is issued and the actual issue is resolved. Pretty happy with my purchase so far.
Did your latch pull down motor still work though?That’s correct tax man. Mine failed less than a month after delivery. ford engineer confirmed water in the connector of the strut. Only difference with mine was that it would give 4 long beeps with not movement
I am afraid to use mine. For regular errands, I just use the back seat. My frunk button under the hood works randomly (25% of the time I have used it). The key fob and inside botton so far have been working OK. I hope someone post a hack to make it manual without freaking out the computer.Man, the frunk is cool and all but it really seems like this should just be able to open manually (without needing to pull the release inside the cab). Y'know, like a regular trunk. Maybe in a future version the powered frunk will be an option and the default will manual.
Hope your issues get resolved!
I'm afraid too.I am afraid to use mine. For regular errands, I just use the back seat. My frunk button under the hood works randomly (25% of the time I have used it). The key fob and inside botton so far have been working OK. I hope someone post a hack to make it manual without freaking out the computer.
I had to donate, one of my favorite cars with a perfectly functioning power train just because I had enough of actuators and motorized functions failing. One of them was the window; Tollbooth people would freak out when I opened the door to give them the money because I couldn't lower the window.
I think Lightning Pro is still better than Rivian or Tesla with regards to the number of things the owner does have control over.
Here comes the last rant of the day:I'm afraid too.
My frunk works 100% of the time from the keyfob and the inside button of the truck. The frunk will open 80% of the time with a push of the button on the frunk, it will close 25% of the time with a push of the button on the frunk.I am afraid to use mine. For regular errands, I just use the back seat. My frunk button under the hood works randomly (25% of the time I have used it). The key fob and inside botton so far have been working OK. I hope someone post a hack to make it manual without freaking out the computer.
