Charley
- First Name
- Charles
- Nov 21, 2022
- Gainesville Fl
- F150 Lightening
- Occupation
- Retired
What is the optimal setting for this switch?
It’s set on 7 right now. Not sure if that is correct. Trying to figure out how to improve my charging speed. Just got my station talking to Ford pass but I can’t seem to figure out how to set a higher charge speed.It must be set not more than 80% of the rating of its branch circuit.
7 is the 80 amp setting which requires that you have it connected to a 100amp breaker with the appropriate sized wiring. It's all in the manual that came with the charger.It’s set on 7 right now. Not sure if that is correct. Trying to figure out how to improve my charging speed. Just got my station talking to Ford pass but I can’t seem to figure out how to set a higher charge speed.
I had an electrician installed the unit and they used an 80 amp breaker. I guess they missed that. Will an 80 amp breaker reduce the charge rate?7 is the 80 amp setting which requires that you have it connected to a 100amp breaker with the appropriate sized wiring. It's all in the manual that came with the charger.
If you have an 80A breaker the station should be set at no more than 64A (80%)...I had an electrician installed the unit and they used an 80 amp breaker. I guess they missed that. Will an 80 amp breaker reduce the charge rate?
So that could cause it to overheat.If you have an 80A breaker the station should be set at no more than 64A (80%)...
Yes, the circuit might be undersized, what gauge wire was used for the connection from 80 amp breaker to EVSE?So that could cause it to overheat.
The breaker will not reduce the charge rate as the charger has no clue what size the breaker is. In this case, if you sustain a charge at 80 AMPs through an 80 AMP breaker, it will work to some extent... But yes, can overheat, can cause strain on the breaker and the wiring as well if it's not up to snuff. This will end in tripped breakers or worse, burn your house down. Your electrician really didn't pay attention on this one or has no clue how EVs work, nor understands how sustained loads work. The latter part about sustained loads is something all licensed electricians should know. And that current National Electric Code states that circuits supporting sustained loads are to be designed with 20% overhead.I had an electrician installed the unit and they used an 80 amp breaker. I guess they missed that. Will an 80 amp breaker reduce the charge rate?
Your charger should be set to 6 in this case. Your install doesn't meet the code as it is set now. Not an electrician but I would expect you will trip the breaker by drawing 80amps on an 80 breaker. You should have your electrician come back. The manual calls for #3 wire on L1 and L2. If they install that size wire and your panel and total input power have the capacity, they could swap in a 100amp breaker.So that could cause it to overheat.
A breaker is designed to carry its rating, not trip at it.Your charger should be set to 6 in this case. Your install doesn't meet the code as it is set now. Not an electrician but I would expect you will trip the breaker by drawing 80amps on an 80 breaker. You should have your electrician come back. The manual calls for #3 wire on L1 and L2. If they install that size wire and your panel and total input power have the capacity, they could swap in a 100amp breaker.
Not sure. Conversation happening with the electrical contractor tomorrow.Yes, the circuit might be undersized, what gauge wire was used for the connection from 80 amp breaker to EVSE?
