hifixenthusiast
Here is the update that I received this evening from AEEsolar. For reference, the following questions that were asked through my point of contact at AEE Solar, who in turn asked then asked the internal SunRun teams.Roger that and thank you for re-confirming. I too have a ticket on this issue opened up with Ford. What I realized during my last customer support call with Ford is that their checklist ends at the Ford Charge Station Pro EVSE. I am still working with a very helpful AEEE Solar engineer and remain optimistic that we will get to a resolution now that the holiday break is over with. I will keep you posted.
Current Status: The system is still functional (after multiple tests), but the 3 errors (LG batteries not present) noted earlier remain and an audible alarm is coming from the transfer switch box. I assume the audible alarm is the result of the 3 errors.
I hope this helps and I will continue to update this thread as I have more information regarding my experience.
Question 1: Is it possible to disable the "Battery" feature in the BDI to clear the errors, but keep the functionality of the CT’s registering power flow? When I have configured the BDI to clear the errors, it doesn't recognize power flow from the CT's.
I believe this is now possible after the recent software update from Delta. There should now be a way to go into the M-Professional app and turn off the battery.
Question 2: How does the Ford Pass application recognize that the system installation is completed and functioning? What experience does the Sun Run installation team have with this feature? Is there an undocumented step that they complete (with Ford) to have this enabled?
The Customer can call our Sunrun Care team and provide the proper information to register the equipment. The registration process is still being worked on, but from there, Sunrun will send the information to Delta to complete registration and then can pass that information to Ford.
Question 3: Should the Intelligent Backup Power system take 3-5 minutes to startup after an outage? or is this partially the result of the Home Integration System not registering in the Ford Pass application?
We have seen backup power transfers take anywhere from 90 seconds to 5 minutes. This is something that Ford would like to improve as the majority of the time is communication between the truck and charger. The Registration of the Home Integration System will not prevent the system from operating.
