Charley
- First Name
- Charles
- Nov 21, 2022
- Gainesville Fl
- F150 Lightening
- Occupation
- Retired
So we may have really screwed this up. I hired an electrician to install a 100 amp breaker box at my pole barn. We installed the recommended wiring from the house breaker box, 200 amp, out to the pole barn. This is where I put my charging station. We put 100 amp breaker in this box and installed the charger according to the installation instructions. The charger now is overheating at 80 amp. (Does fine at 64 and frankly I’m not sure what I really get out of charging at 80 anyway.) What did we do wrong? I wish I could’ve used Sun Run, but those jokers wouldn’t even talk to me, they don’t cover out here in the country.First, you don’t have to charge at 80 amps. It can be lower if you choose, unless you drive 300 miles every day. Second you can get load splitters which will prioritize which item gets the load.
Also check with your power company as there may be other options such as a 320 amp service up grade. Or you may be able to install a separate 100 amp service for the charger.
