MJDore
- Sep 10, 2022
- SE Michigan
- 2023 Lightning Lariat ER
- Occupation
- Finance
I thought I'd add my travels to the other great reports in this forum. I had the opportunity to make the 1,000 mile trip from our home in Northern IL to our second home in Santa Rosa Beach, FL. This was a great test for the truck and for Electrify America charging stations which I used exclusively. I've broken it down by segment below:
Roscoe, IL to Normal, IL
This was the first leg and the one I was most nervous about. I left in 24 degree temps and it had snowed overnight. I left at 5 AM with the truck preconditioned. The first journey was 142 miles so I took it easy, setting Blue Cruise for 68 mph to make sure I would make it in the cold temps and a typical, heavy Illinois farmland crosswind (there's a reason windmills are everywhere here).
Distance: 142 miles
Time: 2 hours 15 mins
State of Charge: 100% to 34%
Temp: 24
Mi/KwH: 1.64
Avg Speed: 63
Charged at Electrify America in Normal, IL. 37 mins to go to 80% SOC in 30 deg temps. 65.5 kw delivered, 109 kw avg charge rate. Plug in charge worked with no issues. $0.00 as still had Ford charging network credit available.
Normal, IL to Effingham, IL
Same as above. Getting warmer as I go South but still only 34 degrees with heavy winds. Feeling better about range, though, so cruised at around 70-72 mph.
Distance: 125 miles
Time: 1 hour 51 mins
State of Charge: 80% to 21%
Temp: 34
Mi/KwH: 1.61
Avg Speed: 67
Charged at Electrify America in Effingham, IL at Firefly Grill. 31 mins to go from 21% to 77% in 34 deg temps. 78 kw delivered, 151 kw avg charge rate. Plug in charge worked with no issues. $0.00.
Effingham, IL to Mt. Vernon, IL
Probably could have planned to skip this spot. 47 degrees now so cruised at around 70-72 mph.
Distance: 66 miles
Time: 1 hour
State of Charge: 77% to 48%
Temp: 47
Mi/KwH: 1.72
Avg Speed: 66
Charged at Electrify America in Mt. Vernon, IL. 21 mins to go from 48% to 78%. 42 kw delivered, 120 kw avg charge rate. Plug in charge worked with no issues. $0.00.
Mt. Vernon, IL to Paducah, KY
Warmer still and feeling relaxed.
Distance: 92 miles
Time: 1 hour 24 mins
State of Charge: 78% to 41%
Temp: 56
Mi/KwH: 1.92!
Avg Speed: 66
Charged at Electrify America in Paducah, KY. 22 mins to go from 41% to 78% in 59 deg temps. 51.5 kw delivered, 140 kw avg charge rate. Plug in charge worked with no issues. $0.00.
Paducah, KY to Clarksville, TN
Debated going for it, Paducah to Franklin, TN. There was an accident on 1-24, though, so I went ahead and made a stop for a break. It backfired as this was the first time I had a charging issue and had to move from one charger to another.
Distance: 92 miles
Time: 1 hour 22 mins
State of Charge: 78% to 39%
Temp: 52
Mi/KwH: 1.82
Avg Speed: 68
Charged at Electrify America in Clarksville. First charger was only pushing around 70 kw. Waited for a Rivian to leave and moved over to get better charge rate. In total, 42 mins to go from 39% to 78%. 56.14 kw delivered. Ford charging credit is gone. $8.56.
Clarksville, TN to Athens, AL
Pretty congested leg impacted average speed.
Distance: 144 miles
Time: 2 hours 13 mins
State of Charge: 78% to 22%
Temp: 52
Mi/KwH: 1.96
Avg Speed: 65
Charged at Electrify America in Athens, AL. 27 mins to go from 22% to 70%. 69 kw delivered, 153 kw avg charge rate. Plug in charge worked with no issues. $0.00 for some reason. I'll take it.
Athens, AL to Alabaster, AL
This ended up being my last leg for the day. Charged and drove to hotel in Prattville, AL.
Distance: 114 miles
Time: 1 hour 45 mins
State of Charge: 70% to 26%
Temp: 63
Mi/KwH: 1.96
Avg Speed: 65
Charged at Electrify America in Alabaster and had to move stations to find a plug that worked. Charged from 26% to 70% in 34 mins. 59.3 kw delivered. $8.10.
Alabaster, AL to Prattville, AL
Stopping for the night
Distance: 61 miles
Time: 55 mins
State of Charge: 70% to 47%
Temp: 66
Mi/KwH: 1.97
Avg Speed: 65
Prattville, AL to Greenville, AL
Up and at em early this next morning. This is my last charging stop before home. Warm morning.
Distance: 48 miles
Time: 45 mins
State of Charge: 45% to 23%
Temp: 64
Mi/KwH: 1.68 (impact of no preconditioning...even on a warm morning)
Avg Speed: 65
Charged at Electrify America in Greenville, AL. I need to charge past 80% as I don't yet have a L2 charger here at our Florida house (installing later this week). 45 mins to go from 23% to 87%. 91 kw delivered, 121 kw avg charge rate. Plug in charge worked with no issues. $10.69.
Greenville, AL to Santa Rosa Beach, FL
Mostly highways from here. Really good efficiency.
Distance: 134 miles
Time: 2 hours 23 mins
State of Charge: 87% to 43%
Temp: 75
Mi/KwH: 2.3
Avg Speed: 56
Thoughts:
--Blue Cruise is incredible. I have a lead foot and don't like being passed, much to my wife's chagrin. What I learned from this trip was how much better I felt after letting the truck do the work and taking it easy.
--Pleasantly surprised with EA. Only had two issues and even those were just me trying to move to a different station for faster charge rates.
--I drove and parked, drove and parked for 20 hours and I'm still on 4.1.1. Can't get OTA updates to save my life. Maddening.
--Be prepared for every Tom, Dick, and Harry to ask you about the truck and whether you're concerned it may catch fire. SMDH
--Preconditioning works.
--For reference, had climate control set to 67 or 68 on fan setting 1. Used heated seats early on.
Distance: 142 miles
Temp: 24
Mi/KwH: 1.64
Avg Speed: 63
Distance: 125 miles
Temp: 34
Mi/KwH: 1.61
Avg Speed: 67
Distance: 66 miles
Time: 1 hour
Temp: 47
Mi/KwH: 1.72
Avg Speed: 66
Distance: 92 miles
Temp: 56
Mi/KwH: 1.92!
Avg Speed: 66
Distance: 92 miles
Temp: 52
Mi/KwH: 1.82
Avg Speed: 68
Distance: 144 miles
Temp: 52
Mi/KwH: 1.96
Avg Speed: 65
Distance: 114 miles
Temp: 63
Mi/KwH: 1.96
Avg Speed: 65
Distance: 61 miles
Time: 55 mins
Temp: 66
Mi/KwH: 1.97
Avg Speed: 65
Distance: 48 miles
Time: 45 mins
Temp: 64
Avg Speed: 65
Distance: 134 miles
Temp: 75
Mi/KwH: 2.3
Avg Speed: 56
Thoughts:
