Brotato
Brotato
Portland, Oregon
F-150 Lightning
What did the modules and parts cost you for the retrofit? Were you able to source used parts?
I ordered everything new from TascaParts.com
The only used part was the steering wheel buttons which I bought from eBay.
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1679079102596
wighty
NY
Check or ask a dealer to confirm. It may also be NL3Z-15K867-G
Well you got me second guessing. I went to the dealer but the parts guy couldn't see any additional description/info, just that the lightning has 4 parts for that harness:
NL3Z-15K867-F
NL3Z-15K867-G
NL3Z-15K867-H
NL3Z-15K867-J
Not sure, but if I could provide him with a VIN for a trim with adaptive cruise already on it he might be able to tell me the replacement part. What is within this harness typically, fog lights (well, not the lightning), parking sensors, adaptive cruise sensor?
3rdgenfan
Geoff
Delaware
NL3Z-15K867-F
NL3Z-15K867-G
NL3Z-15K867-H
NL3Z-15K867-J
Likely could be PRO without copilot/parking sensors, PRO/XLT with just parking sensors, XLT high/Lariat with parking sensors, radar(acc), and then the BlueCruise equipped trucks which have two extra sensors on the sides of the bumper.
jazzmanmonty
Lincoln Corsair
self employeed
does this mod include lane centering?
USA EV
Whoa! Nicely done!
USA EV
OpenPilot might only be a hop, skip, and a jump away?
steveje
Steve
Greensboro, NC
2022 F150 Lightning XLT
Thanks, this is amazing! I got my parts in today and everything installed ok I think but I got to the part where I change values on the C-CM modules but I don’t see the module available.
Any ideas?
One part during installation I was unsure of was the harness. On each end of the bumper were plugs that weren’t used which you mentioned should be for fog lights that we don’t have. On the other end there was one (maybe 2) unused plugs. I didn’t an obvious place to plug them into so I figured they were for options I didn’t have. Should I have plugged them in somewhere?
thank you much for your work and help.
Jasontn316
Jason
Tennessee
I have the parts in and will do the deed on Friday with my 22 XLT Lightning. Where exactly are the six bolts located on the bumper?
steveje
Steve
Greensboro, NC
I tried taking a few pics. There are 3 on each side. You can see them once you take some trim off at the top of the bumper. One of these pics already has the nuts off.
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT C042E1B4-239A-4348-8451-B0E47F09709A
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 0CE34579-996A-44B4-BA7D-369555C31B9F
Jasontn316
Jason
Tennessee
Thank you very much.
3rdgenfan
Geoff
Delaware
Any ideas?
Are you accidentally loading the original profile for the truck rather than doing a fresh scan?
Thanks for these pics, is it a requirement that the frunk tub comes out or can these be accessed withjust removing that piece of trim?
steveje
Steve
Greensboro, NC
The frunk has to be removed. I can’t see how to get to the trim without removing the frunk tub.
As far as the forscan profile, I let it rescan each time. I did not load any previous profiles.
Blochead21
PA
Black 22 XLT 311pkg
Try reseating the pins that were added in the wiring. Could be a loose connection.
