Can not wait for more details! Any idea is the lift is just front coil overs? Or rear as well? It would be nice to have something somewhere between OEM and the $30,000 suspension swap from Saleen.I’m sure they’ll be posting pics soon, I too want to see it lowered although I opted for the lift. So far the feedback from them is that the lift rides and handles amazing. They should be putting on the lowering springs today.
Great! I am even more excited and can not wait to see your truck and their details on the lift. However, I am a bit concerned I went a little too big with my current tires.It’s going to be front coil overs and rear shock spring
Either an inch lower in the front or an inch higher in the rear and that would be perfect for me.
That is their stage 2 suspension system?Better pics, they were able to get 2.6” lift up front, stock rear height with lift in rear using their shocks
Very interested in that lowered setup. Can't wait to learn more!Better pics, they were able to get 2.6” lift up front, stock rear height with rear using Eibach shocks
Lowered, didn’t get Specs
The front and rear both have lowering springs/shocks. I believe they only lowered the front about 0.5", their goal was to sort of level the rear with the front instead of slamming the truck all the way down. The Lowering springs themselves were made to fit stock struts but will also work with Eibach struts if you want the full kit.Is the lowered only on the rear?
I'm with @Pioneer74 on this one, right now you can't tell if there is a slight rake or not, so I'd prefer an additional 1.5/2" drop in the front.I want to say that is what they are looking for, to leave a bit of rake, no noticeable but there.
Bummer! I was dreaming of something like the Pro-Truck stage 2 system like that they have for broncos. Capable of at least 3 inched in the front.For what I was told, they are not going to be looking to make a Stage 2 kit (Adjustable fronts) but that could change.
