Key Fob - replacement
You first. Post a video.
No need, I know it's not an issue. Not the first Ford with the receptacle under the cup holder.
I'm pretty sure it's not $1000 per hour, maybe $100 per hour.
When purchasing any new vehicle, I always get a 3rd key and I think they charged me $200. When the new key came in, it took them 20 minutes to program it. Wasn't a big deal.
You quoted my 4 month old post out of context.
I was replying to charging $165 to do a 10 minute job….you do the math!
cal
Cal
Battle Ground WA
2022 Lightning, Tesla Model S Plaid
First gen Tesla were just as expensive. I lost my fob on our 22 Plaid and was told that fortunately fob replacement had dropped in 2020 to $165 including programming. Back in 2014 it was more than $450.
SmoothJ
New Jersey
2022 F150 Lightning
Does the PaaK count as a "key" so that you can program a missing FOB?
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 Lightning XLT
Contractor
I have a Question:
I have the two key FOB's that came with my Truck,
I would like to make a third one, in case one is lost.
I see I can order one directly from FORD in Hamilton Ontario parts centre, about $140
I also see these Fobs on Toms Keys Company website, for about $87
then checking on Aliexpress they show what looks like the same Fob for $32 (with free shipping)
SO...what's up with the vast difference in prices, and is there a sercurity risk to the 'cheap' ones?
I sure don't need a Fob that reduces the security of the truck.
What is the consensus?
potato
BC, Canada
2023 F150 Lightning XLT ER
I don't know if there is a consensus.
I bought an Aliexpress one for my "third". It exists so I could reprogram a replacement myself if I lose an OEM one. It doesn't have the frunk button; it has a remote start button instead, but otherwise seemed to work fine.
$140 CAD for OEM doesn't sound that bad, really.
If you're going the aftermarket route, make sure you get the correct frequency. Apparently it changed for at least some 2024s. You can confirm what your vehicle uses by looking at the FCC ID on your existing key fob.
I have a Question:
More discussion here
https://www.f150lightningforum.com/forum/threads/issue-programming-a-new-key.18193/#post-365280
I bought the $30 Aliexpress one and it works fine. The 2024’s used a different frequency and I’m not sure about Canada (do you have an FCC equivalent). But you need to make sure the frequency matches. Maybe Canadian key fobs still have US FCC ids?
Robert
NW Ontario Canada
Contractor
Yes FCC is all N.America, although in Canada we call it ISED - same standards really. EU has CE standard.
When I search it looks like the frequency is 315mhz
- From the comments there is no sense in paying the premium price for the Genuine Ford Fob from what I am seeing, just go for the lowest cost option since they all work.
The point for me is to make a spare while I still have two original fobs, since the low cost copy procedure is only available while you have two working fobs.
Maybe good to get two spares, and put them in a safe place after programing and confirming they work. Thanks Guys.
Altivec
Has anyone confirmed that you can program using one of the cheap knockoff fobs. For example if I lost one of my OEM fobs, would I be able to program a new one with one OEM fob and one already programmed Aliexpress one? or do you need both of the OEM fobs to program.
You need 2 in order to program another one. This is a security feature so the kid at valet parking can’t copy your key.
potato
BC, Canada
Apparently, from what I've read, the truck can only have four fobs in total at a time. So if you make two spares, you couldn't add another OEM one later without a trip to the dealer. Seems like a dumb artificial limitation to me but that's what I heard. FWIW
Robert
NW Ontario Canada
Contractor
Good Question,
If I get two cheap Fobs, I will try programing one with the other & an OEM to see.
Altivec
Good Question,
Thanks... I would appreciate that. We use both OEM fobs right now (wife has one). I was thinking about getting a cheap one just in case one of us lose one, but then thought, well what if the one of us that is still using the OEM fob loses it. Can we program another cheap one with the two we would have left (1-OEM & 1-knock off). I am assuming the answer is yes but my assumptions have been wrong before.
