Tailgate opened while in the garage - significant scratch followed
Basis0439
2023 F150 Lightning
Well, I had a nightmare or two about this happening. We have a short garage that fits our truck. The other day, I opened it to the sound of friction. The garage door hinge scratched the tailgate and gouged it down to the steel.
Now, I recall shutting the tailgate earlier in the day and not being super confident that it shut based on the sound I heard. The power tailgate has not given me a ton of confidence either opening or closing...
I guess my question is this: is there anything I can do to prevent this from happening? It is possible that I inadvertently double-pressed the tailgate open button on my keyfob, but it's unlikely.
is there anything I can put on my garage door to prevent this? I'm kind of at a loss, but now I have some mild PTSD caused by opening my garage door.
Thanks for input....
Ford F-150 Lightning Tailgate opened while in the garage - significant scratch followed IMG_20230922_080158_759
The Weatherman
Dean
South Central KY
I don’t have answer to the how to prevent. But I think you can make a change on the big screen to make the gate manual. That might help, because you will have to be standing at it when it opens and when you close it.
I am also a little frustrated with the performance of the automatic tailgate function. It has raised itself but failed to latch several times. Usually a do over will get it, but not always.
ctuan13
Chuck
Pittsburgh, PA
Well it could just be due to the angle and lighting of the picture, but that only looks to be down to the color layer or primer at worst. And the entire body of the truck is aluminum so no steel to worry about! But that still sucks, and I'm really sorry to hear that happened 😕
trailcat
WA
F-150 Lightning - Lariat ER
I'm thinking of adding the pool noodles to my garage wall when my truck is delivered. Now if someone accidentally opens the tailgate using the keyfob, will the tailgate hit the pool noodle and then automatically reverse direction and close?
Basis0439
2023 F150 Lightning
Well mine opened and remained leaned up against the garage door. When I opened, the garage scratched the shit out of the truck. So no, it doesn't automatically close.
kstype
Kurt
Pennsylvania
Senior Systems Engineer
Same garage door hinge scar happened on mine when somoene lowered the door and the truck was not in far enough. I feel your pain.
smaster553
NJ
Mach E 2021 CA Route 1 Space White, F150 Lightning
I put 1" thick foam sheet on the inside of the garage doors. Works like a charm, hides all bolts and metal stuff
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrek… hehe
Developer
reverse the use of a tailgate pad
Ford F-150 Lightning Tailgate opened while in the garage - significant scratch followed image
That’s correct. If it hits an obstruction while closing, it will reverse to the full open position, but not the other way around.
trailcat
WA
Maybe it's just me, but don't you think there's more likely to be an obstruction when opening rather than closing a tailgate?
No. Virtually everything that power-closes acts this way. The worry is that there could be something (even a small child) in between the moving and stationary surfaces.
trailcat
WA
That makes sense. Wish it worked both ways I guess.
