BSull
Interesting thing happened to my 12 Volt battery the other day. I had a Pro logix 2320 power supply / charger connected at the battery. Negative was downstream of the sensor, positive connected to the battery post. When I finished checking available downloads, I decided to charge the 12volt to 100% (it was 90%).
I changed the settings on the charger to 2 amp charge, started the charger and went inside. The HVB was also plugged in. Next morning I went to unplug everything, HVB was @ 90% as it should be, 2320 was flashing an EP in the display window. I turned off the charger, then turned it back on and low and behold the battery had much less voltage than when I left it the night before, % charge showed 75%. Does anyone know what the flashing EP means, it's not in the manual and my search ability online can't find anything?
Anybody else ever experience this?
