Grease Lightning
- First Name
- Johnathan
- Sep 6, 2023
- Albany, Oregon USA
- 2023 F-150 Lightning XLT
In your drive, yes you can do better. I normally would see 2.3-2.5 in those conditions. The difference maybe I don’t use cruise, as I always have seen a reduction in efficiency and I choose to not use heat except for short blasts at 68 deg to defrost.I have owned EVs for over 4 years now and I am aware on how to get good range. Having said all that I cannot get above a 2.1/M avg on my Lightning... Is it really effected by weather that badly? Today drove from Indianapolis to home 150 miles.... average speed set on cruise control was 56 mph, Average outside temp was 48f when I left and I had my inside truck temp set at 65f speed 1. My tires are slightly overinflated to 46psi. I feel like I should be getting better than 2.1 average... whats going on... is this expected ? Side note, I swear I hear what sounds like a slight brake pad is constantly on or a rubbing noise, Is that normal or possibly my issue?
So yes it is possible, but you have to really want it.
