invertedspear
- Jan 18, 2023
- AZ, USA
- Website
- lightningcalcs.pages.dev
- Antimatter Blue XLT (312A) ER, 2004 Jeep TJ
This has happened to me a few times, I was able to tie it to the way I was one-handed turning the steering wheel and the pad of my palm hits the cruise control button. Cruise control has a minimum setting of 15mph. When I'm creeping at 1-4 mph, that acceleration feels like it's gunning it, especially when turning. I think as a precaution @Ford Motor Company should change the way cruise control engages, so that it will not engage below 15mph, instead of engaging at 5mph and setting the speed to 15.I thought I should mention this since seeing this accident and my experience a couple of days later. Whenever I see these types I usually think just like some of you that they must have touched the wrong peddle and are not quick enough realize that they have a problem and need to make sure to hit the break.
But today I was in a parking lot and most all the spots were taken except one I happened to see. So I tapped on the accelerator peddle and the truck just took off like if I had really gunned it. I immediately hit the break anticipating what I saw on the video that I was in for a ride if I could not stop it so I slammed on the break and held it there, but it did not keep going it immediately stopped accelerating so all was good. I kind of wondered if I had just given it too much peddle but that would not attribute to when I took my foot off the accelerator and it was still going until I hit the break. I have not been able to recreate it yet. It might be a specific spot that it does it. I want to find a nice empty parking lot some where and try different taps on the accelerator peddle to see if there is some point where it locks in after you tap and quickly remove your foot from the accelerator. You know if you are aware something might happen like this it is easy to work out a action plan, but if it takes you by surprise it is only the very fast people with quick reactions that will stop it in time. So anyone out there who feels like they can handle this sort of thing see it you can recreate it in a safe place. If Ford is watching these they are most likely trying to figure it out. I hope my experience helps get it solved right away before some one really gets hurt.
