StaggerLee
Austin
Lightning ER 2023
If you use the "INSTALLATION" app, log into the FCSP, then use the "Connect to Ford Pass" function, it's still pulls up the old control panel we had under Account, the historical data is gone, but the adjustment feature appears to be available, I did not try adjusting the charge rate, as I prefer leaving it alone at 80 amps, this functionality was woefully unreliable on the 4 series of the FP App.
Ah ok - thanks for this. So history is gone, but presumably it'll log again starting today?
I don't know for sure, they may be abandoning this whole feature (only a guess not official)
Edit, it's appearing under Energy TAB at the bottom under advanced
Its PJ Bia
Maine
F150 Lightning PRO
So maybe I'm missing it, but how do we control the HVAC on the app? I can turn it on and off from the main screen, but that appears to be it.
detansinn
United States
It appears that remote start, which started the HVAC before, has now been replaced by an fan button like other EVs.
After you start the truck slide up to reveal the controls, tap the Climate Settings
Ford F-150 Lightning FordPass Update 5.0.0 -- Complete Redesign [5.0.3] bug-fix 1716486909935-92
This makes me grumpy.
It makes me angry. They force us to use Fordpass to control the software of the charge station, instead of giving us an independent app. Then they remove it, and the data that we've accumulated over years is gone, along with the functionality.
Just another example of Ford not getting software. I'd even argue that they are getting worse, not better.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
It makes me angry. They force us to use Fordpass to control the software of the charge station, instead of giving us an independent app. Then they remove it, and the data, that we've accumulated over years is gone along with the functionality.
Just another example of Ford not getting software. I'd even argue that they are getting worse, nor better.
With all of the headaches I’ve had updating Ford’s software I can only think of one feature that has improved my experience. Adding the camera button to the home screen is the only thing that has made the truck better since I bought it. Why not just leave the old controls for ProPower, FCSP, and Zone Lighting on a buried screen, why just throw them away? And if the plan is to add them back in the future why won’t they say so?
And the odometer reading. What a stupid thing to omit.
EDIT: OK, I found the odometer reading. It's buried on vehicle health page.
But
You
Have
To
Scroll
Down
To
See
It
Runaway Tractor
Yes
Wouldn't surprise me if the trucks started getting updates again.
Obviously Pro Power and Zone lighting will be added back eventually.
You must be new here
carys98
Cary
Raleigh, NC
But
You
Have
To
Scroll
Down
To
See
It
That‘s what they mean by quicker access.
Ford F-150 Lightning FordPass Update 5.0.0 -- Complete Redesign [5.0.3] bug-fix IMG_0439
Joe.....Montana
Joe
Montana
2023 Lightning
Appears odometer reading is NOT a key feature...
I would NOT consider it a key future...but one of the first things I noticed was "the GD odometer reading is gone"...upon further tinkering I found it. Then questioned why it was so important to me.
