PTS/FDRS VIN Check Thread
2021 Ford F150 Platinum FX4 EcoBoost
would you mind checking this one?:
1FTVW1EL6NWG15248
Your truck is on the latest Sync version and showing only updates pending. Nothing to be worried about here in terms of updates. Your truck is reporting a code that coincides with a possible loose connection between two modules, but if your truck is giving you no issues, then it can be ignored.
Sean J
Sean
Ohio
2023 F-150 Lightning ER
@rugedraw We sincerely appreciate your time and your willingness to help us learn more about our trucks. Is there any chance you can check 1FT6W1EV9PWG46924 when you have a moment? I want to make certain I should be in "patience is a virtue" mode awaiting OTA updates (currently on PowerUp 4.2.1.2 and am pretty sure that's an update I received shortly after driving off the lot).
I purchased the truck new in late April 2024. I've heard you say the modem must be "activated" in order to receive updates. I assume mine's active, since it's linked with FordPass, I can get vehicle status, and in fact my FordPass app reported a check engine code that my vehicle threw yesterday [P0929(77) for the gear shift lock solenoid, although on restart the code is clear and FordPass status shows "Good".] Or is there more to modem "activation" than that?
Thanks in advance. FOMO on my part, of course.
@Sean J Modem is fine and the truck is talking to the mothership fine. I don't see any reason your truck is not getting updates other than it simply isn't being sent any.
I see the code it through and seems to be an isolated incident; glitch in the matrix maybe? If it does not happen repeatedly, I would disregard it.
Bullite
2023 Lariat
Just got ECG-24.2.4.9 not completed did I do somthing wrong ?
1FTVW1EL9PWG12167
thanks
Alambros13
Alex
Bakersfield, CA
2023 F150 Lightning Lariat ER
Hi @rugedraw. New to the forum and a new F-150 lightning owner. Picked up a 2023 Lariat ER this weekend. I’d be grateful if you could look my VIN up in FDRS. I had a few errors day 1 of ownership and had to bring it back to the dealer for a day to correct (front parking sensor, no forward anti-collision, no blue cruise) that appear to have all been corrected by a software update. I also received my first power up last night. Thanks for your help!
VIN: 1FTVW1EV9PWG28726
Scattered
2023 Lightning Lariat
Hello @rugedraw . Thank you so much for providing this service. I don't know how well it will apply to Canadian Lightnings, but could you check.
VIN 1FTVW1EV5PWG19053
Thanks
1FTVW1EL9PWG12167
thanks
According to PTS, it went through just fine.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1719010021097-iu
OTA history shows you got 4.2.1.1 on 6/20 and 4.2.1.2 today. Modules with pending updates are below. Not shown below are several APIM, GWM TCU and at least one IPC update you would need to be fully updated, too.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1719010118030-7t
Thanks
OTA history shows a few updates came in in April; same ones as above plus one more for the APIM which was OTA 23-PU0724-DOM-RS. Your list is below and also need updates to the modules I mentioned above.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1719010278049-du
Bullite
2023 Lariat
Thanks still says not complete ? I’ll assume it will disappear at one point.
Reset the APIM. That should get it to clear.
wafflechef
SF Bay Area
2023 F-150 Lightning XLT
I was on a long road trip and kept getting software update notifications in the in-car display that would say the update was scheduled, but then they'd disappear upon next startup of the truck and didn't seem to apply. VIN is 1FTVW1EL1PWG23485, could you help take a look? TIA
It's a phantom message and you can ignore it. No updates have been sent to you since the end of April.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1719244644430-7s
dalesumjr
Dale
NY
F150 Lightning Pro SR
Your list is below. You're on Sync 23159 which is not the latest, so you also have APIM, GWM, TCU and IPC updates pending.
Hello, would you be able to check my vin again. I’ve had a flurry of updates over the past three weeks. Thanks for everything you do!!
I didn't compare it to the previous one, but the list will most likely the same. The updates you have gotten have been for the GWM and TCU and when those modules have a pending update, PTS does not show it. None of the updates you got would have cleared anything from the original list.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1719266079328-ii
flyct
Jerry
South Florida
F-450 & F-250 Lightning & Tesla Model Y
Blissfully Retired
Can anyone tell me if
vin 1FT6W1EV5PWG16853
has
OTA 24-PU0119-CHG4
has
OTA 24-PU0119-CHG4
It does not show in your OTA history. If that is the update for the Tesla chargers, your truck does show a pending OBCC update, so if that is what you're looking for, then no it has not been sent yet.
