Has anyone successfully used an aftermarket NACS to CCS adapter?
sd22
Las Vegas
2023 F150 Lightning Lariat Extended Range
The Ford email warns about using an adapter that was distributed by Ford. But, I'd like to not have to wait the 3 months for them to deliver it. I can have the Lectron model delivered in 2 days through Best Buy. For anyone who may be an expert, or has just used one of these successfully, do I have much to worry about if I go with the Lectron adapter for 3 months?
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
I would recommend the A2Z instead of Lectron. You probably canโ€™t get is as quickly but there have been a number of problems with Lectron. Some people have had difficulty getting them to release from the Tesla connector and have even had to abandon them at the charger. The original A2Z can be tricky to get locked but they just switched to an improved design the should solve that problem.
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? IMG_0455
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? IMG_0453
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? IMG_0454
ZheWiz
Jack
Central NY
2023 F150 Lariat ER. Less Tech than CT ๐Ÿ˜˜
Database developer
Iโ€™ve used my A2Z used many times, zero issues.
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
I have an A2Z adapter and Iโ€™ve used it at least 20 times without issue. I got it less than a week after the updates rolled out allowing charging at Tesla stations.
bmw325_num99
Jordan
Chicago, IL
2022 Lightning Lariat ER, 2018 Tesla Model 3
I have been VERY happy with the A2Z adaptor. Lots of long road trip miles with it and it has never let me down.
GoodSam
Good
occupying space
My newly arrived Lectron Vortex, 1st try, was successful for 11kWh test at 110kW rate using Ford Plug&Charge. However, another 2024 Lightning XLT there before me, who had about 10 previously successful "supercharges" with his Lectron Vortex could not charge. He then tried my Vortex and still neither the Tesla app or Ford Plug & Charge worked for him. He was at 80% already, trying to get to 90% to have some trip insurance on his SR. Maybe Tesla said "no soup for you" when attempting to fill slower above 80%?
And he did have a past problem with pulling out the Tesla NACS plug unless he let it cool off a bit. He actually did a modification by Dremeling (grinding) a bit off the inside moving latch of the adapter receptacle and he says the sticking problem has not reoccurred. His also a newer Vortex direct from Lectron since the recall was issued. Another person said they needed to use a clamp to press the release button firmly enough to have it release, but I do not know when that one was purchased. Previous Vortex units were too loose in clamping? And some other recall for pre-May '24 units?
See this new thread about keeping the adapters cool for charging on hot days:
https://www.f150lightningforum.com/forum/threads/psa-keep-your-tesla-nacs-adapter-cool.20224/
GoodSam
Good
occupying space
I wonder what the idle charges will add up to ?
detansinn
United States
Since the superchargers opened up in February, I've used my A2Z adapter dozens of times now. It's very well engineered.
From experiences that I have had with other Lectron products, including a Level 1 charger that was drawing too much current from a 110V outlet, I wouldn't touch their stuff. I am totally unsurprised by the issues that people are having with their adapter.
LECTRON and Supercharger charging for no less than 16 times in the last month, over 1,000 miles up and down Georgia and FLorida, and not a single issue.... works great.
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? live oak angle
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? turnpike hard
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? cordele charge.PNG
htobin
Howard
Ovalo TX
Iโ€™ve posted elsewhere on the forum about my experience with the Lectron adapter I ended up using a clamp, but since reading about Grinding down the catch with the Dremel tool, I tried that. It seemed to work perfectly. It doesnโ€™t take much and really isnโ€™t very difficult to do, but if you have the time I would probably go with. A2Z
Ford F-150 Lightning Has anyone successfully used an aftermarket NACS to CCS adapter? IMG_8962
I think you meant to say that it warns about using an adapter NOT distributed by Ford.
Lectron's initial model had to be recalled. Their revision has overheated and shutoff charging for at least one person in the high heat, whereas no one has posted that the Ford, or A2ZEV adapters have done that.
The A2ZEV adapter is temperature tested, along with many other tests. They recently redesigned theirs after some owners found the latching mechanism confusing.
A2ZEV's Typhoon Pro adapter is $193.50 using coupon code FORDFORUM. You'll find that much cheaper than the Lectron. And, if you also want a destination adapter (called Stellar), pick it in the dropdown menu and you'll see a price of $261, 20.2% off. They will ship within a week or so.
Many more people have used the A2ZEV adapter than the Lectron adapter, if that's of any concern to you. I myself have used both A2ZEV adapters many times. https://a2zevshop.com/?ref=Typhoon
EFG
Ed
Lightning, chevy bolt, bmw 1200rt, 23 ford t-bucke
software developer
I have had a failure every time I charge using the Lectron when ambient temps are above approx 95 degrees. runs for about 20 minutes and then trips off. i am going to try the wet rag suggestion today when i charge.
htobin
Howard
Ovalo TX
For some reason, it seems the Lectron is more popular with the Rivian group
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
A2Z works fine (finicky lock that loosens up over time) on both my Lightning and my friend's Mach-E (he takes frequent trips from NC to NJ).
