flyct
- First Name
- Jerry
- Sep 28, 2023
- South Florida
- '24 F-450 Platinum & '23 Ford Lightning Lariat & 2 Tesla Model Ys
- Occupation
- Blissfully Retired
Will this disable the window buttons? My dogs have a habit of stepping on the window buttons and the window opens. I have the rear windows disabled from the driver arm rest button but the front windows still operate.Here are the Dog Mode (sorry, I'm not a cat person) instructions that I've been using in my May 2022 LL:
- AC / Heat On: Be sure it’s set to “Auto” and to, say, 73 degrees.
- Truck On: Leave the Truck Running.
- Lights to Off: Turn the dial to the left until it’s “off”.
- “Power Down” Timer Off: Turn Off the 30 second “Vehicle Power Down Timer”: Note, if you shut the truck off during this process, you MUST repeat this step. This step is required every time you start the truck.
- “Settings”
- “Vehicle”
- Turn off the first setting, “Vehicle Power Down” – This must be manually toggled to “Off” EVERY time (because when the car is shut off, this immediately “resets” to “Timer On”.)
- Manual Cardboard Sign: I put a “Dog Mode” sign over the display. And I’ve pasted these instructions to the back of the sign.
- Open Door: Dash will say, “Truck is Running.” Ignore or press “OK”.
- Exit: You can take the Remote OR you can leave the Remote.
- Lock Truck: Lock the truck by simultaneously pressing the “9-0” and “7-8” buttons on the “Keyless Entry Keypad” (on the door jam.) Confirm truck is locked by confirming the traditional door lock “knobs” are down after closing all doors. If the truck double chirps, it is NOT locked.
- Confirm Running: Confirm the truck is still running. (The dashboard should look like it does when you are driving.)
