mobilesauna
Has anyone powered a mobile sauna from the Lightning? I am thinking of building one and powering an electric heater using the Pro Power Onboard. I have the 9.6 kW set up. My understanding reading elsewhere in this forum that I can power a heater via the 240V if it is <7.2KW and 30AMPs or less. So for instance I might be able to do the Harvia Topclass 6KW, 240V Sauna Heater. It is 6KW, 240V-1PH, 25 AMPS that Heats 177 – 283 cu.ft. Any warnings? I'd like to get as much heat as possible (to be able to do a larger space) so perhaps a 7KW / 30 AMP could work or would that be pushing it? I am not knowledgable at all about electricity. Would it be fair to say run time would be like 15 hrs (plenty of time...which could be 5 hrs over 3 days). I'd welcome any advice? Thanks.
