cdherman
- First Name
- David
- Jul 18, 2023
- Kansas City
- RAV4 Prime, 2016 Leaf
Ok, the Emporia was installed before we even got the Lightning, May 2023, but used rather infrequently when I visited with my RAV4 Prime.
Lightning started using the Emporia in Nov 2023, and used the 48A quite a bit until I got the 80A FCSP installed in March or so.
My brother was charging on a hot day recently and the Emporia faulted. He was not aware that the Emporia could give an error code based on long and short flashes, so he just threw the breaker to stop the beeping. I heard about it -- took me a couple of weeks to head out to western KS to diagnose. I *guessed* it was going to be a heat issue.
Plugged into my RAV4 and nothing bad happened. Derated the EVSE to 40A and the lighning charged fine. But return to 48A and BANG -- the EVSE showed a fault. "Current loss -- check the terminals for damage or debris" was the jist of the explanations in the owners manual (for the EVSE).
Terminals on the Emporia looked fine. Shiny silver like I am used to seeing. I used a small tubing brush and dug around in them regardless. The Lightning was a different color on the two main high voltage (240V) terminal however. They appeared black. IS THIS THE USUAL COLOR? I brushed around on them a bit as well. Did not have the feeling that I had done much good, BUT -- plugged back in and away we went at 48A.
The lightning terms looked ok. Not damaged like a short had happened.
Hmmmm.
Hmmmm.
