Administrator
Administrator
Staff member
Purple State
F-150
Admin
2025 F-150 Lightning ORDER GUIDE (8/26/24) - PDF DOWNLOAD
2025 F-150 Lightning PRICING LIST (8/26/24) - PDF DOWNLOAD
WildBlue
Somewhere
2024 F150 Lightning Flash
From my reading of this, the Flash trim is getting Active-X trimmed (instead of cloth) seats that are NOT heated and cooled; only the Lariat and Platinum appear to have heated seats now in 2025.
Also the mobile charger will have the NACS plug, which would heavily imply that the 2025s will ship with a NACS plug for charging, otherwise what would be the point of this change if the truck still had a CCS plug?
NCMike
Raleigh, NC
2022 Red Lariat Lightning
- Fast Charging Adapter (NACS) is now included with Mobile Power Cord (66A)
The way I read it is the mobile charger will come with the current NACS adapter. Meaning, the adapter we currently use to charge at tesla superchargers. Therefore I would assume it still has CCS. I also think that if the CCS port was gone, they would have added it to the same section of the order guide as a "new/changed" item for the 2025 lightning.
Silenze
Wi
I think they are just going to include the stand-alone adapter with the mobile cord bundle.
Right in the order guide it says there is still a CSS charging plug on the truck. No nacs
Vehicle Charge Capability
— SAE J1772 CCS (Combo Connector System) Charge
Port capable of charging3
on 120V, 240V and Direct
Current (DC Fast Charge)4
— Single Onboard Charging
— Level 2 Peak Charging Rate of 11.2k
Wait...I thought they wanted heated seats in all trims to claim increased range?
Also, spare tire now optional. That's dumb. Disappointed that they couldn't get native NACS too. At least the adaptor/mobile cord for $500 is a slightly better deal than just the mobile cord.
Reactions: N87
WildBlue
Somewhere
This makes more sense than what I said. Maybe this is why Ford hasn't shipped any NACS adapters to us since they are holding them for 2025 deliveries?
jamelski
Sacramento
2024 Lariat
52A Ford BlueCruise 1.2 (1-year Included) 495😳
Silenze
Wi
Big changes are:
Removed SecuriCode™ Keyless-Entry Keypad, Driver's Side. Now dealer installed option.
Removed spare tire. Now dealer installed option.
Moved standard E Locker to optional max tow package.
Removed avalanche paint code.
Lariat is now active x. No Leather seats on lariat.
Also keep in mind that the Supercharger adapter won’t work with AC charging.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
Pro power onboard 9.6kw is a freestanding option now? “But it’s got a heat pump…”
KurtsRPMGarage
Kurtis
Orange County, CA
Geologist
With the standard heat pump its likely not necessary.
KurtsRPMGarage
Kurtis
Orange County, CA
Geologist
Good point, forgot about that.
That said I'm seeing heated seats listed under the pro and xlt so its safe to assume the higher trims have it as well.
Each trim carries over standard equipment. PRO has standard heated seats. Flash will have them as well.
