Ford Charge Station Pro -- only 10KW
mwolff_83843
matt
2024 Lightning
Recently installed FCSP and I am only getting a charge of 10.2 KW. Do I need to adjust something manually to get a faster rate? Thank you.
Follow these steps:
1) Take truck back to dealership.
2) Trade it in for a 2022 or 2023.
3) Go home and plug in.
The 2024s have a single charger onboard, not a dual charger. Max AC rate is 48amps, which is 11.5kW, or 10.7 or so to the truck. 10.2 implies you're a bit below 240v.
DC fast charging is not affected.
mwolff_83843
matt
2024 Lightning
That is interesting. I'm very surprised they don't let you know that in the ads for the FCSP. Frustrating...
The Weatherman
Dean
South Central KY
For sure. You can buy a really nice 48AMP charger for about $400. Not the $1,400 they want for the FCSP.
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Follow these steps:
@Ford Motor Company should have considered keeping it in with the Platinum package since it wouldn’t qualify and help differentiate it more from the Lariat trim. 🤷‍♂️
BeeKind
Long Island, NY
'23 F150 Lightning, '23 Ioniq 5
OP I'm really really sorry for you. I've had this argument now in several places that Ford is doing a really really shit job of informing people of this change on the 2024s.
I hope everyone who is making this mistake posts about it so Ford can see and fix the mistake. There's so much ink and YouTube out there devoted to how ERs can do 80A that it needs to be CLEAR on both the website and window sticker 'Max 48A AC Charging'
EdRudy
Ed
Springfield, VA
What’s wrong with 48A charging? I’ve had my 2022 ER set to 48A since purchase. More than enough to top off over night. Only issue I ever had was lugs at breaker loosened up over time and cause arching. Replaced breaker, tightened lugs to spec, all good.
Runaway Tractor
Yes
There's nothing wrong with it. What's wrong is misleading sales information and illinformed salesmen leading people to believe they will be getting 80 amp charging.
Another stellar job from the sales team.
Adventureboy
It seems to me that it would make more sense to have it in the Pro series or XLT series since these are more likely to be used in a commercial environment and require faster charging to get through busy days. I have a '23 and occasionally dial up to 48 amps to top up overnight after a weekend trip but I rarely use more than 32 amps on a daily basis. I've only used 80 amps once at a hotel destination charger with a decent EVSE.
In any case, the 2nd onboard charger would be nice as an option on any trim level for those who need it.
BeeKind
Long Island, NY
Almost like when you fudge the numbers and make invoice over MSRP and cloud the incentive structure the salespeople are less inclined to know the product thoroughly and sell them aggressively.
I honestly blame Ford more than I blame the salespeople. Communications is PR is marketing is corporate is national. Many salespeople likely don't even know what a Powerboost is over an Ecoboost without looking at the sheet. Ignorant salespeople is nothing new.
To me the problem is the information out there very boldly proclaim 80A as a feature (as it is beefy and industry leading when it was released) and most people are still actively out there talking about the older trucks and trying to figure out if they need/want 80A or less.
I can point to two specific places it needs to be if I were in charge, representing due diligence on top of press releases:
This:
Ford F-150 Lightning Ford Charge Station Pro -- only 10KW 1726579482313-if
Should be this:
Ford F-150 Lightning Ford Charge Station Pro -- only 10KW 1726580444408-co
And this:
Ford F-150 Lightning Ford Charge Station Pro -- only 10KW 1726580478928-2l
Should be this:
Ford F-150 Lightning Ford Charge Station Pro -- only 10KW 1726580600970-dm
Grease Lightning
Johnathan
Albany, Oregon USA
I would generally agree but for most businesses the around 10 hours at 48 amps works as the truck is out of service for a shift. For the companies that are running three shifts, even 20kW is not enough and they would likely need to DCFC unless they are having it sit out.
Sadly there is little use case for the need in general over fast charging, but yes the pro should have an option for fleet orders.
Now if they would have given us two charging ports so I can plug in to two 6kW public stations 🧐🤑
BennyTheBeaver
The Pro does have the option for dual on-board chargers for fleet orders.
I have had a depleted battery when I got home at midnight and have had to leave again at 6am. That's when the FCSP has helped me. Previous to that I charged my SR Pro with 40a, and rarely had an issue.
CAVUBob
Bob
Taylorsville KY
2024 F-150 Lightning
MWOLFF,
I feel your pain. I just learned (from the forum guys) what you’re now learning. My thread was called “Lightning Won’t Accept More Than 46A From Grizzl-E Ultimate 80A Charger."
I initially thought Grizzl-E was the problem, but the problem lies with Ford. They put out the info about the reduced charging, but there are still a lot of pointers that make it seem like 80A charging is still the norm for ER batteries.
CAVUBob
CAVUBob
Bob
Taylorsville KY
EdRudy,
48A is adequate, but that’s not the issue. Ford’s sleight of hand would’ve been good to know (without having to go digging for the info) before we spend money for charging capabilities we can’t take advantage.
CAVUBob
