20k, 18mths - High Volt Batt issue and Wall Charger Issue
derm
Lance
Chesapeake VA
2023F-150 Lighting Lariat. 2003 Ultra Classic
Love the truck. First Issue.
2 weeks ago my wall charger switch to a red bar and my truck did not complete it typical overnight charge. Since then I would charge to 85% but as soon as I backed down the driveway it would go to 83%.
Yesterday I get a Service Now warning and a Stop Safely Now warn ing. Parked the truck and called dealer for pickup and tow.
Today, get a message the High Voltage Battery has Bad cell and will need the truck for a week. (loaner F150 on route from dealer)
Question:
Did the charger screw up the Battery?
Did the Battery screw up the charger?
Does the Ford Charger has warrenty period or part of the Bumper2Bumper?
Thanks
Today also saw the wall charger still has a red bar even when unplugged
Ford F-150 Lightning 20k, 18mths - High Volt Batt issue and Wall Charger Issue 7111549000646347434
Ford F-150 Lightning 20k, 18mths - High Volt Batt issue and Wall Charger Issue 2116292807526431188
Ford F-150 Lightning 20k, 18mths - High Volt Batt issue and Wall Charger Issue Screenshot_20241023_111539_Messages
Ford F-150 Lightning 20k, 18mths - High Volt Batt issue and Wall Charger Issue 20241023_113345
Double check the seating of the dongle into the EVSE case and plug into the wall outlet, if it's still an issue, you're covered, get it replaced.
1. No
2. No
3. Covered by 3/36 warranty. Cycle power to see if the error clears. If not, have the dealer replace it.
Reactions: chl
OMO7
23 Lightning
1. No
2. No
Would this not be covered by the 8/100?
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
High voltage battery and eDrive components covered by this warranty include the high voltage battery assembly, Bussed Electrical Center (BEC), Battery Energy Control Module (BECM), on-board charger, Inverter System Controller (ISC), DC/DC converter, and eDrive.
The Weatherman
Dean
South Central KY
And No! That level one charger did not harm your trucks battery. That thing doesn’t have power to mess up anything , but maybe it’s self.
derm
derm
Lance
Chesapeake VA
did that. no change
derm
derm
Lance
Chesapeake VA
Brought charger to dealer and picked up 24 f150 STX. Miss my Lariatt already...
Question:
Thanks
Those little Ford Mobile Power cords have had many failures. Made by Webasto, sold on Amazon as Webasto Go, many reports of failures there too, some meltdowns, literally.
Not apparently suitable for everyday use, just as an emergency backup on the road perhaps.
I attached the Webasto manual with the trouble light indications fyi
The red light on can mean either it is rebooting after an error "THE MOBILE CHARGER IS
AUTOMATICALLY RECOVERING AFTER ENCOUNTERING AN ERROR.
WAIT FOR THE MOBILE CHARGER TO RETURN TO STANDBY. IF THE MOBILE
CHARGER CYCLES FOR MORE THAN 2-3 MINUTES, UNPLUG THE VEHICLE
COUPLER. UNPLUG AND REPLUG IN THE ADAPTER. IF THE ISSUE PERSISTS,
CONTACT CONTRACTUAL PARTNER FOR SUPPORT."
or
has encountered a non-recoverable fault. "THERE IS AN INTERNAL FAULT IN THE MOBILE CHARGER THAT CANNOT BE RECOVERED TRY A DIFFERENT ADAPTER IF YOU HAVE ONE AVAILABLE. IF ERROR PERSISTS, CONTACT CONTRACTUAL PARTNER FOR SUPPORT."
derm
derm
Lance
Chesapeake VA
Thanks. Dealer replaced. It would go from blue to red in 3 seconds after being plugged into wall.
