New Charging Profile?
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
According to Kyle Conner, the new ⚡'s DCFC at 509 amps instead of 450. Will pre '24 trucks gets an update that allows this?
How long at this rate?
Please post the article.
Louisiana
Tesla Model 3, Jeep Wagoneer
I hit 180+ kW at a Supercharger earlier this week. Carscanner showed that I was pulling 500A. I've got a '22 ER Lariat at 10.x via module updates at the dealer (addressed some CSBs).
Hammick
Kansas City, Missouri
I saw the same when I tested my adapter last week. '22 Lariat ER. It was over 180kw. I should have taken a screenshot.
AZT9
Peoria, AZ
Pulled 182 at a Tesla supercharger I use regurarly. Same charger in all past charging sessions max’ed at 170
@TaxmanHog my peak hold before @170 was around 5-10 minutes @ 40%soc starting. Today @182. Held it for 10-15 minutes.
tnugentfl
palm coast, fl
@TaxmanHog my peak hold before @170 was around 5-10 minutes @ 40%soc starting. Today @182. Held it for 10-15 minuets.
Wow, this would indicate a significant improvement!
The peak you hit isn’t as important as the total area under the curve that determines to time it takes to get from 20 to 80%.
Well, true, but provided the charge rate after the boost didn't change then going from a 5-10minut boost of around 165, to a 10-15 minute boost up over 180, would be very helpful in shortening charging times
March 2024. EA.
Ford F-150 Lightning New Charging Profile? 1000004591
