Ford Home Charger Install by QMERIT
JackieDemarais
Jackie
Whitehouse, Texas
F150 Lightning 2022
This is completely fabricated nonsense. Qmerit is a large electrical contractor and has absolutely nothing to do with Sunrun. Sunrun is it's own company and likewise has nothing to do with Qmerit.
For the current problems people are having, remember who Qmerit works for in this. It is not you. Qmerit is being hired and paid for by Ford. Qmerit cannot do anything Ford doesn't let them do. I'd bet good money the problems with getting scheduled are all on Ford.
I contacted SunRun to have them install a new charger. They said they are using Qmerit to do that for them now. Maybe they are separate but they are working with/for SunRun.
sfringer
Scott
NC
They do not work with or for SunRun. When I received my FCSP from SunRun I could have chosen any installer to handle the install. There was no connection to Qmerit.
You also need to keep in mind that Qmerit subs out the work to a local electrician who has been vetted by Qmerit. So if there are issues with any of the local Qmerit vetted electricians in your area, that could add delay as well.
Note: I used Qmerit (based on @tommolog recommendation) about a year ago when I had my FCSP installed and this is the process that occurred then.
tommolog
New Jersey
www.youtube.com
2022 F-150 Lightning Lariat, 2023 Rivian R1S
Journalist
Qmerit is a network of licensed contractors, the same ones that have been operating in your areas for many years. Contractors can apply to join the Qmerit network and, if accepted, undergo training so they can install equipment to Qmerit standards, which are often higher than what a regular electrical contractor uses. For instance, they have to use high-quality industrial-grade outlets, torque wrenches to make sure all the connections are torqued to the manufacturer's specs (this is especially important for EV charging equipment), and only copper wire gets used for charging equipment.
To your point about extra time, it depends on the specific contractor. Quite often followers of mine have reported same-day contact, but it depends on a lot of factors. Overall, my followers are mostly happy with Qmerit, but there are occasional complaints. And that's another good thing about them - you now have a company on top of the contractor to contact and complain to if there is an issue. If Qmerit gets a lot of complaints about any specific contractor in the network, they remove them from it.
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
Qmerit is the new name for SunRun - the original installer recommended by Ford for the charging system installation. They changed their name because their reputation is SO bad. That’s all you need to know about them.
This is not true.
Qmerit is a large network of independent electrical sub-contractors.
They don't do the work themselves, they use their network of local electricians. If there is a delay in the process, it is because the local installers in your area are booked up - some areas have installs in a day or two, others in a few weeks. It all depends on how busy the electricians are.
This is not true.
I saw one person with a new Mach-E state that Qmerit told them they couldn’t find a contractor in their area. They’re trying to get the dealer to change their purchase from charger to dollar credit without much luck.
broncoaz
Cape Cod, MA
2021 Bronco 2 door Badlands manual
I bought my 2024 F150 on 12/5, contacted QMerit on 12/6 and had the local electricians install it on 12/13. I had an extra 40 feet of cable run over the 10 feet included in the basic installation and they charged me an extra $450 here in Michigan.
It was a very smooth process and I was very happy with both QMerit and my local electricians, Bazen Electric.
They told me the basic install was up to 80 feet?
aldera
Ralph
2024 F150 Lightning Lariat
Who's they?
Basic EV Charging Installation
  • Electrical Panel load calculation including an evaluation of power requirements for all existing electrical circuits and electrical appliances used in your home to ensure your charging installation fits within the capacity of your electrical infrastructure.
  • Professional hardwire installation of a customer provided wall-mounted charging station OR installation of a commercial grade NEMA 14-50 outlet for use with a customer supplied Level-2 charging cord
  • Assumes installation location is within 10 ft of electrical panel.
  • Installation of code compliant electrical wiring and conduit including all necessary connectors and couplings.
  • Installation of a new, properly sized breaker to appropriately support the available load and charging amperage output.
  • Power up charging unit and test for proper operation.
  • Project specific clean-up and disposal.
Scorpio3d
SS/IBA car wash owner
Not much different than Ford being the manufacturer and dealers being “independent contractors” some of them are good and some of them are not all depends on who has been hired for various positions within that company!
broncoaz
Cape Cod, MA
Who's they?
I called Qmerit last week and asked what the standard Ford installation included. Read page two of this thread, others had the same information.
https://www.f150lightningforum.com/...er-install-by-qmerit.23338/page-2#post-452942
I think the problem with the OP is that Qmerit has not assigned him a local contractor yet. Maybe they live in a small town? Still seems odd that Qmerit wouldn't at least say they are having trouble finishing a certified electrician in that area. Something doesn't add up.
You got the FCSP installed with home backup capability for $900??
I don't think I said that, did I? No, my install was just the charger. I was interested in the back up system until others reported so many problems with it. I'm now looking into alternate solutions. I won't do just a subpanel with generator port cuz I want to still be able to use my solar.
Cobalt Blue
Cobalt Blue
Derrick
2024 Lightning
Yesterday’s call must have done the trick. I received an email stating that a contractor had been assigned (the name of the company was provided). I do not recognize the company name, but a Google search seems to show that they do exist. It being Christmas, I do not expect much until next week at the earliest. I’m perfectly fine with that.
thanks to many of you, I have learned a lot about what to expect with my install. I’m probably gonna replace the wire from my house to the carport (-80 feet) with 4/3 copper so that the charger will have an 80 amp service.
Cobalt Blue
Cobalt Blue
Derrick
2024 Lightning
I can likely help if I had their name and address
This is what i received: “VTEC/Gi-Techs Inc is now reviewing your project scope and will provide a final quote for you to approve.”
Thanks!
The Weatherman
Dean
South Central KY
Sounds like something Tom at State
Of Charge could help with. He is tight with Qmerit
. Edit: Hadn’t seen him chime in. Good on Tom.
