This is a new version of the original FORScan thread. @TaxmanHog and I thought it would be good to have a post #1 that can be maintained going forward which was no longer possible with the original.
FORScan allows you to make modifications to certain module settings that change how they operate. The source of many mods is from FORScan guru @Livnitup. He has maintained spreadsheets with module information. You can find them on this thread. MAKE SURE YOU BACK UP YOUR ASBUILT DATA BEFORE MAKING CHANGES. SOME CHANGES WILL BE UPLOADED TO THE MOTORCRAFT SERVICES ASBUILT SITE AND YOU WILL NOT BE ABLE TO RECOVER THE ORIGINAL SETTINGS. ALSO BACKUP YOUR FORScan SETTINGS REGULARLY.
In the settings that follow, “x” means leave the value as is and “-“ is the checksum value that FORScan will re-calculate for you when you write the data. While all the settings can be done using As-Built Mode, some can be done with “Easy” mode. Both are shown where applicable. Post #2 gives links to equipment, tutorials, etc.
Global window open/close using keyfob:
only works on the front windows because one-touch is not enabled in the back windows.
DDM 740-06-02 xxxx xxxx 01--
PDM 741-06-02 xxxx xxxx 01--
DDM 740-06-03 01xx xxxx xx--
PDM 741-06-03 01xx xxxx xx--
BCM 726-11-02 xx01 xx01 xx--
BCM 726-22-01 xxxx xxxx 01--
BCM 726-22-02 xxxx xxxx 01--
APIM 7D0-09-01 xxxx xExx xx—
Or Use Easy Mode from this post
Glare-free (matrix) headlights: localized dimming of brights based on surrounding traffic (pic): The swiveling (dynamic bending) lights continue to work with these settings. May take a couple of restarts to take effect. Settings were adapted from this F150gen14 ICE forum thread.
APIM 7D0-09-01 x1xx xxxx xx--
APIM 7D0-09-03 xxCx xxxx xx--
IPMA 706-01-01 xxxx xxx9 xx--
SCCM 724-04-01 xxx4 xxxx xx--
HCM 734-01-02 xxxx x2xx xx-
HCM 734-03-02 xxxx xxx1 x1--
HCM 734-11-01 0735 89
IPC 720-01-01 xx8x xxxx xx--
IPC 720-10-01 xxxx xxx3 xx--
@FlasherZ Notes here to check to make sure there aren't any checksum DTC's set for the HCM.
Enable Silent Mode (AKA campground / dark / police mode)
Creates a SYNC toggle to turn on/off Silent Mode. Silent Mode turns off cluster lighting, welcome lighting, courtesy lights, SYNC screen, and silences the horn when locking doors. See this post for more info, pics, and how to enable using easy mode.
BCM 726-25-02 0101 0101 01--
BCM 726-28-02 01xx xxxx xx--
APIM 7D0-09-02 Dxxx xxxx xx--
Assumes current value is "C". If "E", change to "F".
Disable double honk with exit of running vehicle:
There is a Sync
setting for this this (Key Detection Alert). FORScan not needed.
BCM 726-63-02 xxx0 xxxx xx--
Lincoln Folding Mirrors Setting (folds when locked; unfolds when truck started instead of unlocked):
DDM 740-03-16 xxxx xxxx 01--
PDM 741-03-16 xxxx xxxx 01--
Note: has issue that puddle lights get disabled.
Remove "Full view not available" message on reverse camera screen while in motion (source)
APIM 7D0-02-02 xxx* xxxx xx--
If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7. Note: reset APIM after the change
Disable Seatbelt Reminder:
IPC 720-01-01 xxxx xx0x xx--
This can also be done on a per-seat basis via instructions in Owner’s Manual (link)
Disable Seat Belt chime on vehicle startup. The truck will chime 4 times if you press Start with the seat belt disconnected. This is the US seat belt strategy. You can change to the European seat belt strategy which waits until the vehicle is in motion to chime.
IPC 720-01-02 xxxx x2--
Disable Door Ajar Chime
IPC 720-01-02 xx0x xx--
Assumes you had "2". If you had "6" change to "4" (24-hour clock).
DRL Brightness Adjustment (original post) (not recommended)
This setting affects the DRL which is the lamp between the top and bottom headlamps (pic). It is not the light bar which is on XLT and above. Careful - you may get flashed by oncoming drivers if turned up too bright.
BCM 726-42-01 x2x2 xxxx xx--
BCM 726-38-01 xxxx 64xx xx--
example values are 64 =100%, 4B =75%, 32 = 50%, 19 = 25%, 0A =10% (default).
Change Number of Blinks for Turn Signal Tap (original post)
SCCM 724-01-01 xxxx 8Cxx xx-- for 3 blinks (default)
SCCM 724-01-01 xxxx 90xx xx-- for 4 blinks
SCCM 724-01-01 xxxx 94xx xx-- for 5 blinks
SCCM 724-01-01 xxxx 98xx xx-- for 6 blinks
Enable B&O Beosonic Equalizer (B&O Sound systems only) See this post for info and screenshots. Reported not working on 2024 Flash (
post). Please reply to that post if it works for a 24+.
APIM 7D0-01-01 xxx* xxxx xx-- Add 8 to * (mine was "1" so made a "9")
DSP 783-01-01 xx*x xx-- Add 1 to * (mine was "0" so made a "1")
Walk-away Lock (WAL) – 2022-2023 only, standard on 2024+
Note: this only enables toggles on the Sync Screen for toggling WAL and WAL Feedback (horn honk). To get the actual functionality you need the BCM updated from the dealer. See this post.
APIM 7D0-09-05 xxxx Cxxx xx--
Or APIM Easy Mode: enable Walk Away Lock and Walk Away Lock Feedback
Fix front camera not popping up on screen when front sensor activated (source)
IPMA: 706-16-01 xxx*-xxxx-xxxx
if old value 0-7 then add 8 (hex) to get new value. For example 3=>B. If current value is 8-F, then this is not for you. Applicable to trucks without Park Assist and BC.
Fix Small 360 degree camera view – issue with some 2022 models after IPMA update
APIM 7D0-01-04 xxxx xxx3 xx-- change from "2" to "3"
Change Tire Size for Speedometer Calibration
Use BdyCM easy mode. Setting is Tire Circumference (mm). Also see these two posts: Easy Method (video), As-Built method (use addresses 726-15-01 and 726-15-02). Also possible DTC.
Heated Steering Wheel Temperature Setpoint (source)
SCCM 724-06-01 Bxxx xxxx xx-- default 35°C
0=24°C 1=25°C 2=26°C 3=27°C 4=28°C 5=29°C 6=30°C 7=31°C
8=32°C 9=33°C A=34°C B=35°C C=36°C D=37°C E=38°C F=39°C
Trailer Side View - shows corresponding camera view alongside of vehicle when turn signal is applied with trailer connected. See here for details. Note: requires newest 12/23 IPMA update.
IPMA 706-01-02 *xxx xxxx xx-- if 0 change to 3, if 7 change to F
APIM 7D0-02-03 xxxx x*xx xx-- if 0 change to 8, if 4 change to C, adds Trailer Side View toggle under Driver Assistance
To get started with FORScan you will need:
- A Windows laptop
- The FORScan for Windows software. For programming you can get a free Extended license for a 2-month trial. Instructions and download are at the link.
- A dongle to connect the laptop to your car’s OBD port. For programming the FORScan team recommends the following two wired dongles on their website:
* OBDLINK EX (OBDLINK Website, Amazon). I’ve used this one and it works great.
* Vgate vLinker FS (Amazon)
* You can also use a J2534 Pass-Thru adapter like the Mongoose.
Livinitup’s tutorial is highly recommended. It explains how to make back-ups, checksums, etc. https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit?tab=t.0
EdRudy
Ed
Springfield, VA
Disable Door AJAR Chime - (Verified 2022 Lightning Lariat)
Disable Door AJAR and Seatbelt chime on vehicle startup -
IPC 720-01-02 xx0x x2--
EdRudy
Ed
Springfield, VA
I enabled Glare Free lights and changed the DRL's from 10% to 100%. After making the changes people were regularly flashing their highbeams at me.
I can see the glare free lights working as expected but I think changing DRL's to 100% makes them too bright giving the impression I am not dimming my highbeams.
I changed the DRL's back to 10% and will test them this evening.
PJnc284
Garner, NC
I didn't notice a difference at night between 10% or 100% when I did mine.
EdRudy
Ed
Springfield, VA
I didn’t either, but apparently, oncoming traffic seems to have noticed. If I still get highbeam flashes from oncoming traffic I will assume Glare Free is the culprit.
IPC 720-01-02 xx0x xxxx xx--
IPC 720-01-02 xx0x x2xx xx--
Thanks! I'll add the door ajar one (with edit for 24-hour clock). I already had the seat belt chime in there.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1735771532715-nz
Note this is one of the addresses that has less than 10 bytes of info, only 6.
So it's "xxxx xx--" instead of "xxxx xxxx xx--"
EdRudy
Ed
Springfield, VA
Edited my previous post.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Thanks for explaining and not having to read 500+ post.
Can you give is an idea what the equipment cost and licensing after the intro 2 months period.
Will this also allow us to push BC 1.4 instead of waiting for the OTA update that will never come fast enough.
And for kicks, wil this get us our Tesla Adapter faster than others???
Rick
You can click on the links provided to see the cost of the OBD dongles. IIRC around $40-60. As for software, after the 2-month license expires you can request another. Currently the FORScan folks are unable to take CC payments from the US but again, you can always request another trial.
You can get BC 1.2+ by getting your IPMA and PSCM updated at the dealer. There are then FORScan changes that can then be made to enable In-Lane Positioning and Lane Change Assist. Those changes aren't being made public but if you read the BC 1.4 threads, you can find assistance.
But you have a 23 so should be getting the OTA. I think there is a holiday pause right now but maybe soon.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Thanks, sold the 23 pro. Have the 24 Flash. Ford is not interested in updating the BC 1.4 even with a paid subscription.
So Ford, who would go to the market and pay full price for a gallon of stale Milk when there is fresh Milk on the shelf right next to it.
Get off your butt's and push the update, at least to people who are paying for a subscription.
Hard to argue about the free Tesla charge adapter when we're not paying for it. But BC, we are paying for it.
Rick
21st Century Truck
Martin
The same thing happened to me when I increased DRLs to 50%. I then changed the DRLs back down to 25% and this seems to not piss off oncoming traffic while making my DRLs brighter for sunny daytimes.
EdRudy
Ed
Springfield, VA
I tested last night after setting the DRL's back to 10% and no one flashed their highbeams at me. Seems to have worked. I don't think the DRL's were blinding anyone, I think it gave the impression my highbeams were on and I wasn't dimming them.
