It took a while to pop up. I just started in Accessory mode in garage and went to the Update screen. Was still just showing 10.1.1 Complete from Dec 12. I let it sit for a minute or two and was about to turn off when the screen above popped up.
UPDATE: Ended up driving around on errands and when I got back 12V was 75%. So I clicked Install Now. Took 46 minutes with the usual buzzing bees noise. When done 12V battery was at 76%. So clearly they did change OTA functionality to allow the HVB to charge the 12V during updates. HVB went from 66.0% to 65.5%.
The official name of the OTA release is IPMA-24.204.10.9 based on release notes and follow-up survey. Sync version did not change. Only issue so far is minor - it set my radio to AM but I didn't lose presets.
I've got carscanner, but have not checked my 12v. I started in the garage earlier around 1 and no luck. Ran an errand about 2 and no luck after 2 starts. Will get out for dinner in a bit, will see if that will trigger. I'm usually right up front with you and others.
The 12v situation has never delayed a download if I recall. That was just an impact for installing.
Downloading happens when the maker wills it so, pull up seat on the second stringer bench Greg!
Yes I agree on the 12v. I got the downloading message when 12v was 57%. But decided not to do an install at the time. But then changed my mind after some driving!
Did you get 10.1.0 and 10.1.1 plus getting the front sensor CSP? Not sure if the CSP is needed since this OTA updates the same modules. But 10.1's may be needed. One was GWM, the other was generic connectivity IIRC. And Karaoke :rolleyes:
Caliber357x
‘23 Lightning Platinum
took my Lightning to dealer and they cleared out the software update glitch but still did not receive the 1.4 update. 🙁
‘23 platinum here - it seems those that have received the update just recently are all ‘22 models, unless I missed someone in the thread. Just drove 100 miles today and was in good AT&T coverage, but no joy on the update. Tomorrow is another day.
PJnc284
Garner, NC
Guess they decided to give 22's some love before finishing the 23's. Haven't seen anyone with a 23 report anything this round.
wapple24
New Jersey
‘22 here with no 1.4. Took a nice drive and nothing. I am usually a week behind the first people to post here…so hopefully soon.
I did get 10.1.0 (12/6) and 10.1.1 (12/19). I have not had the sensor CSP done. Made my trip out for dinner and no download after 20 minutes in the truck and 2 starts. I'll go ahead and schedule the sensor CSP, I need to buy off the technician anyway and get my BMC updated. I really would like WAL more than an updated BC. I rarely have a chance to use BC and likely only a couple more times before July when my 3 years will expire.
SmoothJ
New Jersey
2022 F150 Lightning
How large in size is this update? Been watching my WiFi connection at home and saw it download a few MB. I have not drove it since though.
A couple of MB is not enough. My truck downloaded 162 MB today. But download can also happen over cellular.
You really need to start the truck to check. Only after I started it and waited a couple of minutes did I get the message that an update was downloading.
Since this is an inhibit update, FordPass will also give you a message that an update has downloaded and ready to install. This is what I got after the download completed.
Ford F-150 Lightning Bluecruise 1.4 officially being sent out to F150 & Lightnings starting today (12/11/24)! 1736654322864-d2
Ford F-150 Lightning Bluecruise 1.4 officially being sent out to F150 & Lightnings starting today (12/11/24)! 1736654055595-zd
SmoothJ
New Jersey
2022 F150 Lightning
Would a remote start work too?
