Riverant
Same experience as me. Note that you do “have” BC 1.4. While you haven’t enabled the new toggles for lane change functionality (which IMO is more a gimmick), you do benefit from improved functionality and should experience fewer dropouts and smoother behavior.Hello folks. Been watching all this for a while.
I got a Mongoose and FDRS license for the first time yesterday and ran through the process to apply all the outstanding updates to my 2023 Lariat.
I didn't have any problems; all the updates I ran seem to have gone through their process successfully. No DTCs prior, and no DTCs now afterwards. However:
I applied the IPMA update before the PSCM update, which applied successfully and then immediately moved on and applied the PSCM in sequence, also apparently successfully. The PSCM update was not removed from the list of pending updates though, even after a clear-and-retest and a close/reopen of FDRS. So, I applied the update to the PSCM directly, with the same result.
- ACM update was apparently successful, but didn’t clear (as previously reported)
- Another module whose name escapes me (Remote Function? Bluetooth Low Energy?) applied successfully, but didn't clear (as I believe has been previously reported)
As a follow-on I tried running the "IPMA- Image Processing Module A (IPMA) Configuration" process as described by @Mike G in #4,096, but no change—PSCM still shows in the pending updates list.
I went for a drive last night and everything seems fine with the truck; no dashboard warning lights, cameras all work and are in the correct dimensions, BlueCruise is working (though apparently in whatever pre-1.4 state I was in before).
I think this aligns with at least some other folks here who have not been able to get the PSCM update to clear, but consider me another data point. If I've missed a step or there's something else I can try before midnight tonight, happy to try and get that done. Otherwise I'll likely let this ride for a bit and see if these changes shake any OTAs loose.
Thanks all for your ongoing insights! This is a great community.
