Short drive testing Auto 1 vs Auto 3 in 7 degrees F.
Ford F-150 Lightning Cold Weather, Hot Data: Heater Power Usage and Exterior Temp Screenshot_20250114_165635
Beginning is warmup as I left my house.
The second bit, 735-745, was Auto 3 at 70mph (ish).
The beginning of the third bit (747-75) was Auto 1, also at 70mph (ish). The last bit was Auto 3 again.
21st Century Truck
Martin
Thanks this is useful data.
Yeah
What is unusual to me is that Auto 1 appears to use more energy than Auto 3.
Of note, today when leaving work with cold soaked battery the heating system did not warm the battery, even though power was even limited due to temp.
Scorpio3d
SS/IBA car wash owner
Yeah
What about sport mode? People have said that it will cool the battery in the heat I wonder if it has the opposite effect in the cold??
Yeah
Interesting, what was your outside temp?
I got a 10 minute session of spontaneous battery warming at 19°
Outside was high 20s (F), battery temp min was 28, max was 35, and reported "temp" was 30. Truck had been outside for 8 hours. Power was limited to 92% for my entire 20 minute drive home. Coolant Inlet temp stayed at ambient, heater power usage was only for hvac (turning hvac off had power usage go to zero). Battery temp mode was "Eq" through car scanner.
Edit. Even more fun. Just fired up the charger to see how the temp changes just charging, turned the truck on so I could monitor with the obd port. With HVAC off the heater kicked up to 8kw, even with the battery at 50 degrees F.
Not going to see much increase in SOC with the heater sucking up 8 or my 11kw...
Edit2. Temp went up to about 65f and the heater is off now
Funny you mention that, I rarely use sport mode but did use it for about half the drive home.
With power limited by temp down to 92% (at 80%soc) i would think Sport mode would be more likely to heat the battery.
That said, i did switch to normal and tow/haul once I was home and in the 30 seconds to a minute I tried those modes the heater did not start warming the battery. I'll try other modes today.
IIRC, it was said, that Tow Mode engages extra cooling and possibly warming during cold season.
I did a test of that a few weeks ago, didn't notice an appreciable increase on the battery temperature gauge.
I'm interested to see if that is true. That said, not sure if the truck will sit long enough today to find out. That, and, if I'm being honest, I don't really feel like parking it outside overnight just for you all...lol
fitek
Peter
Washington state
Ford Transit 350EXT
I insulated my Transit van with Thinsulate and 1/2 and 3/4" polyiso and covered the unused windows with Reflectix and it made a noticeable, though not major, difference, especially on the coldest days. At least drink cans don't explode if night time temps go below 32f. Anyone know whether there's insulation of any sort in the LIghtning? My Transit van had almost nothing, wife's Porsche has those ripped up jeans IIRC.
