- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2001 FORD RANGER, 2023 F-150 LIGHTNING
I am using one of those under garage door cord protectors I bought on ETSY for $10.00 right now temporarily - to keep the door bottom level and keep out pests, I put some 1x2 under the rest of the garage door when using the protector.Has anyone one come up with a good way to run their ford charging cable under the garage door. I park my new flash outside the garage and just had my charger installed today. I’ve noticed that the garage door doesn’t close all the way and I also want to try and protect the cable.
https://www.etsy.com/listing/1042599140/ev-charging-cable-garage-door-pass?ref=cart
But my upgrade plan is to put a pass through port/hatch like this which was designed for a FCSP CCS1 cable:
https://makerworld.com/en/models/661390#profileId-588627
Description
This is a cable hatch sized for a CCS1 style EV Charger. The model consists of 3 parts: the 2 pieces that clamp onto the cable and the body. The body is sized to fit through a 5inch hole created by a hole saw. This was designed to clamp onto the cable provided by a Ford ChargeStationPro, but can be resized to fit whatever diameter cable is needed. I have to modify the mounting surface for mine to fit on my angled siding, but this is different for each use case. Adjust the mounting surface angle as needed. Magnets are required for the two clamp bodies. The main body is screwed to the siding with a ¼" flat head screw. The two combined clamp bodies are then rotated into place to secure. If desired, additional magnets can be used to secure, but this is optional.
But I think a regular dryer vent, RV pass through hatch, or the like, modified a bit if needed, will work as well.
https://www.amazon.com/LCGP-Electri...d_r=1d66cfaa-cd8e-497a-8444-27cee2206d33&th=1
See also:
https://dougnet.home.blog/2018/09/01/evse-garage-pass-through-instructions/
