VTRedWingsFan
My truck was updated on 10/09.
I had gone from July to October with no updates and then a flurry.6.14.0 was my most recent update back on 9/6, it's now 6+ weeks and nothing more has come about, so I did power down (disconnected LVB) for 30 minutes, don't know if this will help or not.
2022 Lightning Displays Multiple Faults at Startup
Hi all,
I've been watching this forum for a couple years now and finally have something to post!
I drove my '22 Lightning home yesterday, plugged it in to my Ford charger, it charged up to 80% successfully in the evening, and I went to bed. This morning I loaded the kids up to head out and there were multiple faults rotating through the cluster: Front Motor Fault Service Required, Service AdvanceTrac, Pedestrian Surround Fault Service Now, Trailer Break System Fault See Manual, Cross-Traffic System Fault, there might have been another one in there. Tried to turn it off and back on, wait a while, etc. and no dice. I got an update a few days ago, but it was successful and everything has been fine. I haven't had any other issues with it. Any thoughts that might help? Of course this happens on a Sunday when the dealer is closed, right before Labor Day... when I'm guessing they're closed.
- M
Just in case anyone is interested in my saga from 4 months ago... I'll try to keep this short.It’s at the dealership right now. Hopefully that’s it, but I’ll report back when they figure it out.
Leave your truck running while you are out. I recieved 6.5.0, 6.8.0, 6.14.0, and then the ECG all with in or two days of each other.I got this update finally today, following getting 6.8.0 installed last week. I'm slowly inching my way towards being current! I think ECG-24.2.5.6.2 is coming next week for me.
I think where I like the new top bar icons most is on dark mode, they blend better.
Congrat's this is typical progression from a MY22 point of view.I think ECG-24.2.5.6.2 is coming next week for me.
How do I see if I have ECG-24.2.5.6.2?Congrat's this is typical progression from a MY22 point of view.
24.2.5.6.2 might have been pulled off the shelf in lieu of 24.2.5.6.3How do I see if I have ECG-24.2.5.6.2?
I only know how to select software update details in menu.
Latest is 10.1.0
I've never seen ECG-24.2.5.6.2 format.
For these updates, just starting the truck would trigger the download. I know you're being safe, while leaving it running, but truly that part isn't necessary. Once started it will continue to download and install if you shut it off.Leave your truck running while you are out. I recieved 6.5.0, 6.8.0, 6.14.0, and then the ECG all with in or two days of each other.
I expected that due to the 12v draw, the cellular modem may not be continuously powered if the truck was turned off.For these updates, just starting the truck would trigger the download. I know you're being safe, while leaving it running, but truly that part isn't necessary. Once started it will continue to download and install if you shut it off.
Just glad that Ford is continuing to catch up more trucks.
