Garyl
Go Back and read the OP post:
4000 mile's of driving with no tire manipulation
Only 1 stud unaffected by the time OP reached Dealership
"The studs had sheared off, not just missing lug nuts."
"There was no damage to the wheel to indicate loose lug nuts"
The studs failed. Most likely explanation was Over Torqued. The other potential fail point would be under hardened studs which could be a big Ford problem.
And I wouldn't expect much more information from the OP after reading the comments from others here.
