Ford Perimeter Plus Security System
astrand1
Alex
Studio truck driver
Well part wise it’s pretty cheap so you’re not going to get hurt buying it. To pop the console down you want to use a trim tool and gently pry down on the 2 rear corners. It will give you enough room to get your fingers in there and just start at rear and move forward and it will pop down. Just don’t pry at front. Once down there should be a blue box there. It’s a dummy box. Just empty but the small wiring harness will be plugged into it.
Blochead21
PA
Black 22 XLT 311pkg
What does adding this do for the truck? Just like a shock sensor?
XENOILPHOBE
DC Swamp
2024 F-150 Lightning Platinum, 2024 Tesla Model X Plaid, 2024 Model Y AWD
Retired Army
astrand1
Alex
Studio truck driver
Yes sir. Works as designed.
Jim Lewis
Jim Lewis
San Antonio, TX
And after the FORScan edits, controls at least to turn it on and off show up somewhere in the SYNC screen settings? The reason for turning it off might be leaving your wife or your dog locked in the truck while you pop into a store to get something. (I anticipate possible jokes about the last sentence! 😃 )
astrand1
Alex
Studio truck driver
lol. Yes so once it’s installed and set up you will then under vehicle have a line for alarm. You choose that then you can have it set to ask if you want motion sensors on or off each time you turn off the truck or have it not ask each time. That’s the setting I have it on.
watts/up
23 Pro SR
Can someone elaborate as to the required FORscan changes? Maybe I’m just missing them but I couldn’t find them in this thread nor on the site. I did find them elsewhere for the Gen14 ICE F150 but I assume those are not exactly applicable… thanks.
watts/up
23 Pro SR
For the newly Lightning'd among us.... what does this module do?
From what I gather it's an interior motion sensor and, possibly(?), an inclination sensor. Here's the thread I alluded to previously, linking specifically to a user's explanation. Here are the FORScan changes for the ICE version. I have no idea if these are correct for our trucks. What's interesting to me is that at least one member had the actual module installed but not configured from the factory. Although doubtful, I'm tempted to pull down my overhead console to check.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I’m waiting for my ordered module to arrive….
Price so minimal I ordered it regardless.
I am pretty sure my truck does not have anything other than the dummy box up there. It was a deleted item on my truck from factory.
watts/up
23 Pro SR
Curious if you were able to install this yet. If so, can you elaborate on its use, etc.? Is it both an occupancy and inclination sensor?
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
My blue box hardware arrived and is in hand. I have yet to have sufficient time to get it done as of yet. I’ll start looking around for the proper FORScan changes and instructions today. I’ve only used FORScan once before and that was a couple years ago. I’m personally more concerned about the FORScan process than the physical install portion.
MJFlanigan
Michael
Atlanta, GA
2023 Ford F-150 Lighting XLT
Bro I added back the advanced security pack into my 23 lariat in about 15 min. Super easy. The part itself is like $35 if I remember correctly. Then you just pop off the center upper console from the roof and there should be a blue dummy box that you take out put the new one in and then there is some forscan work and done.
Which part did you use? I'm interested in doing this in forscan
astrand1
Alex
Studio truck driver
I shared it a few posts back. It’s a screen shot from varsity ford.
