Services for remote climate start & charge monitoring failed today
Early this morning around 0615 I tried remote climate start to get out for an early breakfast ahead of snowstorm, truck refused to start.
Later after we got home with hot coffee in hand, I decided to plug in and top up the truck in case we have power issues during or after the storm, the truck is charging just fine, but Fordpass does not show the charging statistics.
Departure timer would not take a new event record, process timed-out.
@Ford Motor Company your servers are on the fritz {again}
BTW: further confirmation of server status ..... the truck is [OFF} and charging but not according to Fordpass!
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738846526827-g3
VTRedWingsFan
Vermont
2023 F-150 Lightning Lariat ER, 2020 Escape
IT delivery
I know it's not the same thing, but my truck was ready at my planned departure time of 0715 ET. So, at least one thing was working right in the Ford cloud.
Glad it ran for you, I would hope that a successfully stored DT event would run autonomously regardless of cloud control failures, might not report back an accurate status but at least it ran. Ideally that's how I envision DT's to operate.
FordPass is updating correctly for me. I haven't tried a remote start but it's reporting my DT and updated when I pulled the screen down.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
Beyond frustrated with the app at this point. I had no problems with it for 2+ years but the last month has been :poop:
VTRedWingsFan
Vermont
IT delivery
Agree. I did get a message in the app inbox.
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738848211688-ki
awilli1010
SE Michigan
Mine failed to precondition this morning also.
Since we moved to version 5.x.x the android variant that I use no longer does an 'animated' pull down to refresh like it did in version 4.x.x
I usually touch the lock/unlock to test communications, but I was in bluetooth range so the lock routine worked fine, it's just failing telematic control features.
I'm using Emporia to monitor the charging progress, IIRC the dash IPC said I was at 58 54% SOC, not the 59% you see above. Expecting it will take my truck 2.6 hours to reach 90%.
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738850426642-ii
Ford Webserver to vehicle control panel is running with stale data, comms failure might be on the truck side.
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738850754048-rv
Bigisland Guy
Ed
So Cal
Retired Old Dude
Just Checked Play store App {Android} notes Item #3 for ver 5.11 update: "Effectiveness of cabin conditioning may be reduced by extreme outside temperatures". You can draw your own conclusions.
Well the 5.11.0 on my android is showing what I consider bloat ads... This just showed up this morning. And like many Ford issues now they want me to buy blue oval network access :crazy:
I got that too, I had to LOG OUT, clear cache, force stop then log in again to resolve that.
Also had to accept a new TOS on FORD.COM this morning when I first logged in to do a systems check.
Something's amiss
The charging session lasted a little longer than I projected, warming cycle for the extra time.
Started 7:01 ended 10:09 using gross energy of 55.6 kWh to 90%, Truck is still failing to phone home
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738855093363-kr
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738855261413-9i
Ford F-150 Lightning Services for remote climate start & charge monitoring failed today 1738855285083-e
