Home Vehicle Charging with lots of solar panels and net metering question.
Dino
Dean
Nashville area
23 XLT Lightning, 22 Volvo XC 60 plug-in hybrid
My house load, with literally everything on is not more than about 6-7K. I definitely make more than that at peak times. My solar array will generate upwards of 14K, but not quite what the charger will attempt to pull from the truck at full bore.
But as I mentioned before, the reason I got confused is b/c I can only read the meter and it's not in real time b/c it gives snapshots, and that's why at times I was seeing numbers that didn't make sense. . .
I have a 7kw (19 panels) solar system, 10 kw battery backup, and a SolArk 12kw inverter. I had my solar installer connect a 50 amp plug to the SolArk inverter via Smartload (input or output configurable). I have that set up to become active/hot when my home battery becomes 45% charged and will turn off when/if my home battery drops to 20% charged. By having this setup my excess solar production (sunny days) is charging one of my EV's during the day (retired) via a configurable charging cable at 16 amps/4kw. When EV charging, my solar sends about 4kw to the vehicle and about 1.5kw to my home and/or home battery.
If you do not have a home battery system, a solar system will shut down during a power outage to keep from back feeding the grid and putting lineman in danger of electrocution.
Rip
Rip
2024 Lightning Platinum
Quality Consultant
Exactly.
The way I think about it is to consider an illuminated solar panel as if it were a battery. If you don’t draw any current from it, it outputs no energy. When you lose the grid, the inverter simply shuts off and no electrical power is drawn from the panels. There is no power “going to ground” or anywhere else.
That's a great answer, and very clarifying. Still, it's waste. The potential is there; but you would need a battery setup to capture some of that potential.
Sure….if you want to always extract the full energy available you have 3 options: use it, send it to the grid, or store it.
Frankhpns
Frank
Milton, Florida
2023 Ford Lightning XLT
Retired military
I have a similar system in Florida with 56 400 watt panels. You sell what you don't use back to the utility. You can't adjust the charge rate on your truck other then changing the charger with a lower charge rate. In Florida the utility buys back my power at the same rate they charge me for theirs Your truck has its own battery charger.
MaintGrl
Marsha
El Sobrante, Ca
Lucky you, Out here the utility ads all sorts of fees to their buy back rate.
and I might note , , , WE have the second highest Electrical rate in the nation. . .(nothing to brag about)
Frankhpns
Frank
Milton, Florida
Retired military
We pay between 12 and 18 cents per kwh depending on TOU rate. Makes it affordable to drive an electric.
MaintGrl
Marsha
El Sobrante, Ca
Ya, I'm paying $.50 kWh, Bout the same as which would be for a ICE
Jodokk
Me
NC
22 Lightning Lariat ER, Agate Bl., Max Tow & AT tires. UnderCover Abyss Tonneau
College Professor
Can you show us a pic of what you are seeing in your monitoring app when you're experiencing this?
My solar array has Enphase microinverters, and use their app rn. I'm getting a Franklin Battery in April, with the generator hookup for the truck. My local power company gives me only around 1/4 for buying back my solar electric overage.
(Our rate is $.11)
My app shows "Exported," "Imported," "Net Spent," and "Produced."
Would you mind showing us what you're seeing?
Ford F-150 Lightning Home Vehicle Charging with lots of solar panels and net metering question. 1000010932
Rip
Rip
Quality Consultant
In Maine they don't buy it back, per se. We get "credits" so if I send a KW to the grid, I get a KW back from it later. Sort of like getting store credit instead of cash back.
MaintGrl
Marsha
El Sobrante, Ca
So, if you create more than you use . . . you get nothing, that sucks. I'm sure the power company loves that...
MaintGrl
Marsha
El Sobrante, Ca
Rocket808
Rocket
Los Angeles
Sorry- i didn’t read through all of the posts
I too live in SoCal and has the Sunrun system
I’m in SCE and NEM2.0
If you are in NEM3.0, I don’t know the math as well
The thought process is : NEM2.0 uses the grid as the battery
NEM3.0 you need your own battery.
Hence why NEM2.0 is a lot better if you have reliable power - and if you have the HIS, then the truck is there to power everything if the power is out.
But as NEM2.0 - it doesn’t matter if you charge during the day or night as long as it is not during peak power - you get 1 for 1 in the off-peak and super-off-peak time windows.
the information the Sunrun app is pretty dismal - so for your type of question it is hard to get a deeper amount of info
your inverter is the driver for instantaneous power. The SunRun app shows you (on the chart tab) power generated per 15 minutes (in real time). Any power over this is being clipped
I have the E8 inverter (unfortunately didn’t get the E10) and it maxxes out at 2kw per 15 minutes or 8kW per hour. The E10, I believe, is 10kW per hour. If your charging at 15 kWh then you would be pulling over the max of either inverter
not sure how your electrical provider app is, but SCE shows net power : power generated and power consumed per day. I have been checking (for me) that generation > usage
anyways, I wish I knew more about the instantaneous usage, but in reality, the daily assessment is good enough
you seem to be wanting to be “off grid” with your questions?
Rip
Rip
Quality Consultant
No, it's not that we get nothing. If I send them a KW while producing, then I get it back when the sun goes down. I've only had this for about a year (they connected it up in April last year). During the winter, my electric bill goes up to a max of around $800 a month during December and January. March looks to be about 400 (and that's with low sun and still fairly short days here in Maine). April gets cheaper, and from May-September my bill is often less than 10 bucks a month.
If I get the money, I will put in a battery backup. I'm hoping that helps capture the excess potential during the day (when it "clips" at 10 KW) as well as providing the primary backup when the grid goes down.
MaintGrl
Marsha
El Sobrante, Ca
Ya, I give during the day, and receive a lil at night, But I also have batteries. For the year (My system was put on-line April 8th 2024), my meter has rolled back about 3.5k kW. It will be interesting what my True-up will look like. I had solar before, removed it for a re-roof, decided to get a bigger system w/batteries (Old system was not compatible) was w/o solar for 10 months, received a $1,900 true up back then. I will see what this next PG&E bill says...
Note: New system was due to intended Lightning Purchase
Richie740
Rob
Does everyone have some form of off peak power? I have solar panels but almost all of that goes back to the grid. I charge at night for less than half of what I get paid for what was produced.
I charge at night as well so most of my power gets fed back to the grid. During the summer months I produce approx. 50KW each day. I'm in California and I recently changed my pricing schedule from TOU where I was paying 45-55 cents whether peak or non-peak a KW to EV2 where I now pay 31 non-peak and 61 cents peak a KW.
I think for the main post question it would be easier not think of what you're actually producing at the same time you're charging at that moment but calculate everything in a single day. If you're solar produced 50KW during daylight and you charged that day 70KW then you drew 20KW from the grid not included your other household appliances regardless of what the meter is stating. If your solar is producing while you're charging that energy is not going to the grid.
