ProPower can now be used with vehicle off?
petemill
petemill
Pete
Santa Barbara, California
'22 ER Lariat +PRB +Unleashed, '11 ford escape v6
Software
I'd like to be able to just start ProPower, turn off the truck and lock her up. Woudl be nice to have ProPower control on the app.
Well of course but in emergencies for a few hours it's not a problem to leave the vehicle on. The main issue is overnight / multi-day camping when the vehicle being on uses 400W consistently. Thats 7% of the ER battery per day wasted on nothing.
John Becker
Cincinnati
That's a painful gross waste of energy.
Heliian
I had a 12 hour power outage a couple weeks ago and used PP to run the house. After a few hours I realized I hadn’t turned off the shutdown timer but it never turned off. I need to experiment again to see if there’s been a change to the setting.
P. 183 of the manual:
When you switch the power outlets on, the
vehicle power down timer is disabled and
the vehicle continues to be powered on.
Now, I'm not sure if there might be a threshold of power usage also. With no load, I found it did shut down but with a continuos load it didn't shut down.
More testing required to confirm.
GoodSam
Good
occupying space
I think I saw 380W with the a/c running. I left the a/c on to keep the cab cool for groceries and a refrigerator kept inside. Was a nice spot to cool off when temperature was over 90F outside with no breeze!
MRButtler
Matt
2022 Lariat Lightning
This is even more puzzling now. If 12V battery gets charged when the truck is awake as well as when it is sleep, then people fixing their update problems with charging the 12V battery must be just in their mind and a matter of coincidence.
I note your sarcasm, and paraphrase:
It's documented that 12v batteries are charged when vehicle is on (sometimes for an hour), because that's the only way some were struggling to get updates.
Or max limit of when charging stops does not match the min limit of what some of the updates need. Or parasitic power loss is higher than we thought and charging frequency lower than needed to top off for update to succeed.
The 12v batteries are on the lot under-charged or frozen. The battery can sulfate to uselessness, unless reconditioned through a special charge.
has anyone hooked up anything to record when and how often power is flowing into their 12V and at what voltage/SOC it stops?
Suggest looking on the forum for the people who have used CarScanner, who recorded this type of data.
For those interested, here is a useful thread regarding 12V battery maintenance from the Mach-E forum:
https://www.macheforum.com/site/threads/how-to-recondition-service-your-12v-battery.11069/
jimfigler
Orchard park, NY
Anytime I have used my Pro Power in the bed my timer always disables automatically. I have verified the timer is active, then I plug something in and timer is disabled
ryun
Earth
Did this update ever come to 22-23 model years? I remember reading we'd get the update in 2024.
Not yet, we still need to have the truck in run mode, but when selecting the PPOB functions it automatically switches off the automatic shutdown.
Hammick
Somewhere in MT
I also read that the Flash models were supposed to have the new "generator mode". I'd really like the ability to turn PPoB on or off from the app and see the power meters on the app again. I'd still have to make a trip to the garage as my truck throws a ground fault if I turn on the pro power with the charger attached.
