dre276
andre
NJ
2018 F150XLT, 2021 F150 XLT 302A Lead Foot
You can change and enable the surround sound in your Sync 4 screen in options. It'd defaulted to Stereo I believe.
i’ve looked everywhere but not seeing the surround sound option in sync4. I had the base sound system but recently replaced the ACM for HD radio. Was wondering if its a forscan change for surround sound
Derek83
Derek
Ontario
2011 Mustang GT, 2021 F150 SCREW Lariat
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 20220128_204810
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 20220128_204819
Apbling
Andy
WI
21 XLT 302A
Hi guys. Been watching this forum for a while and finally joined. I did some simple things like Bambi mode and double honk but I was really waiting for cameras while in motion. I haven’t checked for a while but I now see with 3 module changes use earlier build 21 guys can get it? Is there any glitches or hangups with this or is it good to go?
thomps33
AK
F150
Does anyone have a recomendation for a cheap computer where its sole use will be running forscan?
emiantan
Utah
Future Vehicle 2022 Ford F-150 Platinum
You are the man!
Based on this info I was able to enable Auto heated and cooled seats.
Seats automatically heat or cool based on internal truck temp and selected temp. You will also see a APIM display of your temp selection and whether you are in Auto mode or not. Manual control is retained via the buttons. I just implemented this tonight and everything seems works as expected in auto, but I haven't done any long term testing, so mileage may vary. You will need heat / cooled seats and auto climate for this to work.
My truck is a 2021 402A Tremor which is equivalent to a 502A Lariat. Other trims should verify your original as-build against the spread sheet for possible differences.
HVAC
733-01-08 xxxx x1xx xx (Original As-built 0)
APIM
7D0-02-02 1xxx xxxx xx (Original As-built 0)
FYI - I am not sure if it was user error on my part; however, changing the APIM module to add auto heated/cooled seats removed the Auto temperature readout in the status bar on the SYNC display in my 22MY Platinum. For those unaware, 22MY does not have the LCD temperature readout for the current setting in the climate control dial as pictured in ROBB1's post which Im sure his is a 21MY. Us 22MY owners are dependent on the status bar to show the current climate control temperature for our auto temperature settings. When I reverted to the APIM As-Built, the temperature readout returned. I am sure I could play with the value to retain the temperature display and the auto heated/colled seats, but I don't think I will use this feature much anyway. Thanks to ROBB1 for all of his help on this feature and others and of course Livnitup for paving the way for all of us.
EDIT: As I was playing around with the settings in my truck last night, I noticed auto heated/cooled seats are included with the 22MY Platinum and could be toggled on/off in the remote startup settings.
dre276
andre
NJ
seems like I don't have that option in mine. Was wondering if anyone knew the codes to enable that feature in Forscan.
jcaspar
Jeff
Sacramento CA
2021 F-150 4x4
I think the only requirement is having Sync 21146 Rev 145 (at least for me with early 2021 truck). I have not had any glitches or loss of function with the 3 module changes.
Snippy
F150
Admittedly I haven’t checked this thread in a couple weeks, but when adding cameras in motion (mine was successful) is there a way to activate the tailgate camera? The button is there on the screen, but tapping it does nothing. Currently have bed and hitch camera in motion. Thanks!
Apbling
Andy
WI
21 XLT 302A
I’ll have to look what I have. I know it updated last night….
Sbdavis1
Stephen
Fayetteville
2010 F150 Lariat ordered 2021 F150 Lariat
Financial Planner, Lawyer
When trying to backup all modules before writing my mods, I managed to back them all up but the SOBDMC. Can't imagine I'll be making any changes to that module anyway but was curious before proceeding if anyone else has had this issue? When I run it, I get a service procedure has been interrupted fault. Thanks!
El Amigo
Aris
2021 F-150 Limited
Manufacturing (ODM)
I encountered this as well, no idea though
Raicilla
Rudy
Upper Left Coast
2021 F150 Lariat SCREW AMB 157" PowerBoost 7.2kW
FYI - if you set the Lincoln Autofold option, it disables the under mirror puddle lights.
Love the "Lincoln AutoFold" tow mirrors, but I like the Puddle Lights better (so I had to switch it back...).
Anybody able to get Lincoln AutoFold AND Puddle Lights to work at the same time??
Ruffiano99
Joe
NY
2021 f150
Tried doing the Forscan cameras at speed with no success. Is this supposed to work even if the truck has never received any OTA updates. Got a job 1 platinum powerboost.
tcp
Trieu
Kansas City,MO
2021 F150 Platinum, 2019 Accord
IT MGR
Works for me, did it last week. I got OTA 2.3 a few weeks ago though. Might help if you list your Sync version if others are on the same with it working they could help.
