Adding SecuriCode to Pro?
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
jimfigler
Orchard park, NY
50 minutes?…No fair! You already had the door apart once and scouted it out!!
Haha. Just kidding. Glad to see it went well. I also dropped a plastic connector into the door and had to find it with a snake camera!
Enjoy!!!!
That is very true I had the door off twice and pulled the window seal out so I had a good head start on what to do. Plus I never replaced the triangle piece by the mirror, the cover under the door handle and the red reflector. I did find a foam washer on the garage floor that fell off one of door clips. I may have to go back in and replace it. Probably just stops potential rattle.
jallen
Smart man! Big time head start.
jimfigler
Orchard park, NY
I had purchased the trim piece with cutout. But I also bought a template to make the cutout off eBay. The precut piece arrived first so I used it. I just cut out the original trim. Does anyone want it? I’m a trusting guy. Just pay shipping and it works for you then send me another $30. You’ll save about $50. It cost me $102 for the cutout piece from Tasca with tax and shipping.
Ford F-150 Lightning Adding SecuriCode to Pro? BA367F6A-E0D9-4C55-8F00-9CF1FD013E24
asianman35
Baltimore
2023 Antimatter Blue Pro
I'll take it, PM sent
jimfigler
Orchard park, NY
Anyone want this for $15, got it on eBay for $30 plus tax. Just the green template, the trim piece in photo not included
Ford F-150 Lightning Adding SecuriCode to Pro? 072687AC-FE0D-4FC9-8D4E-38461C2B4E21
BennyTheBeaver
2023 Lightning XLT ER
I found a two key procedure to get my code. I also found two settings, one in BCM that lists keypad. When I enabled it updated 726-31-01 xxxx xx01 xx—. I also found a keypad in APIM and I enabled that. It updated 7D0-01-02 xxxx x2xx xx—.
both of these I had written on scrap paper I had written down awhile ago.
Finished my Securicode install this weekend when I installed new speakers in the front doors.
Fishing that wire through was an absolute pain, and I also dropped a screw in the door which I had to fish out (careful when attaching the new trim piece, every screw hole for the trim is directly over the window chsnnel). Programming was, as usual, the easiest part.
I didn't realize the backlights are now that crisp white LED and not the old green backlight, it's a nice touch that matches the puddle lights.
@jimfigler Thank you for your help, I utilized the same settings you mentioned here with no issues.
BennyTheBeaver
Accidently discovered a nifty shortcut today. Entering my code a second time within a short period of time, opens the frunk.
šŸ¤·ā€ā™‚ļøšŸ¤£
*after entering unlock code
jallen
šŸ¤·ā€ā™‚ļøšŸ¤£
You made me go outside and try a bunch of options on mine. Turns out just hitting 7/8 after my code opens my frunk!
So Cool!!
Does just 7/8 work for you?
Wondering if you just hit that again anyway as part of your code?
Also, my button under the grill won’t shut Frunk after I open it this way. Yours the same?
BennyTheBeaver
So Cool!!
I'll have to try again, my code does use multiple buttons.
asianman35
Baltimore
I was able to successfully install the securicode keypad on my 23 Pro today, thanks for the help @BennyTheBeaver and @jimfigler (your trim piece worked perfectly).
Hardest part, as everyone has said, was fishing the wire down, but it wasnt too bad. Just jam something down the hole after it (i used a wire fish thing), and eventually youll be able to grab it from inside the door. I also lost a screw down the door, luckily i found it without too much fuss, i was able to get my hand down to the bottom of the door and found it.
took me under 2 hours total, most of that time felt like pushing the wire down and then finding the missing screw. other than that, it was pretty straightforward.
I found this video helpful for removing the trim piece.
Minh
Minh
NJ
Hello all
Got this installed today and working however my frunk opened by itself after a few hours later. Anyone having same issue?
asianman35
Baltimore
Hello all
Not by itself, but I pressed some series of buttons that opened it
Minh
Minh
NJ
Ok thanks. I hope it’s a fluke. It was closed when I check the camera alert I received when package arrived so I know for sure it was closed while watching tv at home (not holding key fob).
jallen
Pressing 7/8 after entering code will open Frunk.
Pressing 3/4 after entering code unlocks rest of doors other than drivers door.
