Any range gain within spare removed?
dustintinsley
Dustin
Salem, CT
I know it doesn't remove much weight but it surely affects aero. Anyone remove their spare and test to see if there is any potential to gain a little range? Understand the "no spare is not smart" debate and I am good with not having a spare tire....
Maxx
From what I hear, weight does not make much of a difference in range. If removing spare and smoothing out the bottom happen to make significant difference at high speed, you could put the spare in bed and have it all. That is if you don't use all the space in bed for other things.
For me personally, there is not much incentive to try it since most of my drives are on local roads and in summer I have been getting 2.7-3.6.
Runaway Tractor
Yes
Weight does little to nothing to the range. I really can't see the tire under the truck making much in the way of aerodynamics.
That’s what roadside service is for
That's a very debatable topic. Roadside service could be anywhere from 10 minutes to 10hrs wait. And if the tire has damage that can't be repaired, you're now getting towed somewhere, and still don't have a tire to replace it. Maybe none of this is an issue.
This a strategy and risk that's up to you to decide how important or vulnerable you are. Where you drive, how far from home, how far from service, do you have cell service where you drove, kids/family in the truck.
IMO, there's nothing to gain by removing it, and a lot to lose.
I doubt this. If it did, ICE F-150 forums would scream this. They don't.
Calvin H-C
Calvin
Ford made a big thing about the Lightning being the only EV pickup with a "full size spare" as standard equipment (Rivian and Tesla made it an option) for the reason that as a working truck, it may be likely that one may be in a place with a flat where roadside assistance is a long wait or not an option (no cell service to call).
Then they provided a jack that can't safely lift a three ton vehicle.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Not sure exactly how much improvement I got, but I feel the underside is quieter and the airflow is definitely smoother by putting a hard plastic cover on the spare. Looks better from the rear too.
Don't remove the spare, aero will be significantly worse. Bumper would act like a parachute. Best to smooth the air with this since weight isn't a big consideration.
This one fits perfect and I've had zero issues for a year now.
Hummer H3-33" Rigid Tire Cover (Plastic Face & Vinyl Band) - Black Textured
https://a.co/d/5vjUYAW
Ford F-150 Lightning Any range gain within spare removed? IMG_8236
Ford F-150 Lightning Any range gain within spare removed? IMG_8237
Ford F-150 Lightning Any range gain within spare removed? IMG_8238
dustintinsley
Dustin
Salem, CT
Nice idea. $200 for a tire cover though?
csukoh78
Nope
SE USA
Yes. Looks better at a minimum and protects the tire. Definitely smooths air. I get 2.3-2.4 highway now, but I also have lowered it two inches and much lighter wheels.
but there is a reason the Teslas and Lucids are baby butt smooth underneath. I was actually surprised at how rough the area behind the rear half shafts was.
anyway. Up to you, but it 100% doesn't hurt and does look cleaner and functions cleaner.
dustintinsley
Dustin
Salem, CT
Thanks. I will look into one for sure.
Effonefiddy Lightning
Alfred
23 F150 Lightning SR Antimatter Blue /2023 Model Y
I was thinking of put it in the bed just for ease of access.
