carys98
- First Name
- Cary
- Jan 15, 2022
- Raleigh, NC
- 2023 Lightning Lariat SR
- Occupation
- Retired EE
All of the energy delivered to the truck has to either be dissipated or stored in the battery. Any heat produced is the energy that is dissipated. For example, if you put 12 kWh into the truck and the battery increases by 10 kWh then 2 kWh were dissipated as heat. You canโt store 10 and dissipate 5 if you only put in 12. If you figure out a way to do that you will become very rich.One KWH is just a measure of energy used. Heโs implying that it could be charging and heating at the same time I would guess.
