I had an email that there are still openings to join the waiting list for early access to the pre-order list for a non-refundable $100. Looks like maybe the non-refundable route is indeed a better solution to gauge interest.
mattskr
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
I don't think mine is refundable either and I honestly doubt I would buy it unless they pull off something something magical here that makes it must have. However, I'm honestly curious enough to burn $100 just to see if Ram does a better job than Ford did on the reservation process.
As much as I love the Lightning at some point it will be dated and the buying process will probably be one of the biggest factors on which I go with next. Gimme buy online and deliver it to my house with no nonsense and I'm likely sold.
jimfigler
Orchard park, NY
I think it is refundable until the point that ordering starts, after that it is non-refundable. Or something like that
F150ROD
U.S. Navy Retired
Ford F-150 Lightning Competition: Ram 1500 REV Specs Released - Range, Towing, Payload and Charge Time Info IMG_1662
Ford F-150 Lightning Competition: Ram 1500 REV Specs Released - Range, Towing, Payload and Charge Time Info IMG_1663
They even copied the Lightning Charging port smh
As far as styling I was hoping they would stick to the concept
FordLightningMan
Upstate New York
F150
168kwh or 229kwh (I think he said) is a huge battery. If Ford's next truck and CT are in the same ballpark, better sell our Lightnings and upgrade before they aren't worth anything! Being an early adopter has its pros and cons.
mattskr
mattskr
Matt
Austin, Texas
Range - Standard Battery 350 miles. Extended Range: 500 Miles on 229kwh
battery
Standard Range battery is 168kw - larger than Lightning ER!
  • 0-60 in 4.0 seconds.
  • 14000 Towing
  • 2700 Max Payload
  • 15 cu ft frunk
F150ROD
U.S. Navy Retired
No way, this Gen Lightning will be a classic Ford Product.
Sure, you’ll probably lose value right now, but in the long run it’ll be like those old Ford Pickup Classics running around.
As far as 500 miles…. I’ll believe it when I see it. Tesla hasn’t cracked the 500 mile range yet.
3rdgenfan
Geoff
Delaware
Oh my. That standard range battery is almost enough to make the jump.
Let's see what the pricing winds up being.
astricklin
99 Mercury mountaineer
If it meets your needs then keep it long enough till it's not worth anything anyway.
astricklin
battery
  • 14000 Towing
  • 2700 Max Payload
  • 15 cu ft frunk
14000 lbs towing won't come with the standard battery and 2700 payload won't come with 500 miles. Def going to be an either or on those two specs.
theblunden
NC
2023 F150 Lightning XLT
40k starting price? Haha where's there's smoke there's fire they didn't even entertain the idea of pricing. 168kw pack of it LFP is going to be f'n heavy. This presentation was here's the shell of our new truck bye guys. Open the frunk at least.... What a joke 🤣🤣🤣
