lurker
23 Lightning Lariat, 22 Mach-E
SWE
FYI if you had issues with the front sensor being blocked, enable it again and see if it’s fixed after this update.
Mine appears to be resolved after this update now.
You may be right! I got this update today, read your comment, and went on a drive. My truck used to beep at every stop. It did not do that today. Will report back if it reoccurs.
artificial_airspeed
Fort Worth, Texas
2022 Ford F-150 Lightning | Lariat SR
Random question, the theme on the Sync 4a screenshot looks black. My 22 Lariat SR doesn’t have a black dark theme, it has a deep blue theme.
KennyB123
Ken
Detroit, MI
Check your drive mode. You might be in sport mode. Blue is normal.
lurker
SWE
I take this back. I am still getting the front sensor blocked message.
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
mine came back today. WTH. Is so clearly a software issue when an update makes it go away for a few days then it just pops right back. So frustrating. Maybe one day.
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
I would take it more as a coincidence. If it was software, it should not be back days later with no additional software changes.
Jamchampnate
Nate
Utah
So you don’t think it’s a software bug? The sensor warnings?
Mmiketa
Virginia, USA
It could be, but it could easily be hardware. I am just saying that I don't think it not showing up for 3 days following an update is a confirmation that it is a software issue. I'd honestly lean the other way and say that since you got an update and it's still happening there's a larger chance it's hardware related.
Jamchampnate
Nate
Utah
I had them check it out at the dealer twice and they couldn’t find anything wrong with the sensors at all. All diagnostics showed they all functioned and responded. It started happening after four months of ownership immediately after a software update. No issues before that. No impacts. Nothing on sensors.
Jenovalente
Jens
Charlotte, NC
2023 F150 Lightning XLT
So let me make sure I understand....
Those people that are continuously getting updates are now getting an update that will help them get more updates?
But those of us that aren't getting updates, continue to fall farther and farther behind.
Makes alot of sense, @Ford Motor Company.
:clap:
RedLightning86
Wisconsin Dells
If you aren't getting updates, go to a dealer who says they can update your truck. Once they do, you should be able to get them. They can run diagnostic at same visit, too. If your dealer says they can't do that, then go to one who has a clue or isn't just trying to only do service where they can overcharge parts and labor. And when you find a good dealer, stick with them - well worth it! For example, telling you what you DON'T need, and when you will need something.
OtterJohn
Philomath, OR
Got the update yesterday, which was a nice surprise. Still hoping for the one that shows SOC on the left battery dial, but I'll take any updates I can get at this point. :)
So it looks like this is only for '23 trucks - maybe those that didn't get any updates for months and finally got the 4.2.x.x earlier this year.
Through the posts I don't see anyone with a '22 report it. I was at the front end of most releases. Last update was a failure for me - truck was in the shop for a battery module on April 2 - 23-PU1024-6CH-AUD.
Looks like we are just on hold. Maybe BC 1.4, maybe Walk away lock, maybe allow PPOB without truck being started. All of those are queued up. I know they have to be packaging them in one big update that is going to surprise us all.
