ECG-24.2.5.7 - Gateway Module
What a worthless forum. Five pages of non answered questions
The posts on this and many similar threads are reports of successful receipt or failures of an update.
Happy to have you add some value if you can
He has - in his only other post on this "worthless" forum :). User name says it all.
Ford F-150 Lightning ECG-24.2.5.7 - Gateway Module 1740876974612-o7
Effonefiddy Lightning
Alfred
I would like to see them fix the issue of the music starting 50ft. from my truck before I even get in. It should start when you open the door. But I'm not holding my breath.
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
Anyone noticed weirdness with preferred charging times and Charge Station Pro after this update?
It’s constantly “starting charging”, then says “scheduled” then the charge station resets and it loops. I had to remove the charging times to be able to even charge normally because clicking “start” would cause the charger to loop and the airflow flap on the front to go up and down.
Ricks Lightning
Los Angeles
Plumbing Contractor
I too received 2/27/25 the same update on my 24 Flash . Noticed it on my Ford pass app. I wasn't plugged into my charger and it updated.
Looks like a mass ota update around the same time frame for us non EAP users. Does that mean when they release BC1.4 we will all get it around the same time?
My guess is 1.4 will come on 4/1. Yes, I called it first.. it only makes sense.
That's the feeling I'm getting, rounding up all the loose ends before a big roll out of BC-1.4, when that will happen is anyone's guess, April fools day could be the day.
detansinn
United States
I got the ECG-24.2.5.7 update on Saturday morning. 2023 Lariat ER.
It’s encouraging so many trucks got this update at the same time. I am stoked at BC 1.4 coming soon. Fingers crossed.
PS. My kid brother just got a new 2024 Flash. 👊👍 The Lightning brotherhood is now literally a brotherhood. 😂
