Ford Lightning one pedal drive
ka-chow
Scott
2023 Lightning XLT
DJ
I just have settled into Sport Mode. No one pedal. Seems to be my happy place. There’s plenty of regen there anyway. But doesn’t feel so abrupt.
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
Better than regen to the battery, I have used my OBD reader to show the hydraulic pressure in the brake system during a typical 2PD stop that showed 100% energy returned. The brake pressure is zero. No friction brakes used (except at the end to hold the stop). I've posted the graph from CarScanner in one of the several other threads on this topic.
Why is that better than regen to the battery? No one is saying that your brakes were applied if brake coach says you got 100%...so we know that the hydrolic brake pressure is 0 without the OBD reader. The number that would shut everyone up (I think) is to see at max regen for both modes how much power is going back to the battery. If one achieves more regen than the other, we have our answer.
Bingo, I've started logging my trips to see what the max flow into the battery is while I'm driving. I'll give it a week, grab the highest and then attempt the same with 1 pedal. I'll also try to max it out though I don't want to brake check anyone so it will be situational if I can pull that off.
Firn
23 Pro ER
I didn’t say for everyone. I specifically said that it is not for those who can’t figure it out or don’t want to.
That is literally stating it is better for everyone...
It's great you like it, but I constantly use cruise and regularly coast down for various speed changes, traffic conditions, and other events. I can literally push one button on the steering wheel, that is better than having to hold the gas pedal and modulate speed. Same for light traffic on the highway. In fact it's the same for many of the stop signs and intersections here.
potato
BC, Canada
2023 F150 Lightning XLT ER
Because if the friction brakes are not used, there is nowhere else for the energy to go but into the battery. If you measure battery power in/out, that does show that some amount of regen is happening, but due to blended braking there could also be some energy wasted as heat if the friction brakes are applied at all. If the friction brakes are not applied then no energy is wasted. It is physically impossible for 1PD to recover more energy than 2PD if the friction brakes are not used.
If you disagree with that last sentence, then please explain where the kinetic energy went if not all of it went back into the battery via regen.
Henry Ford
0PD. That's a new one to me.?
Henry Ford
Having one steering wheel to steer in both directions is better than one steering wheel to go right and another wheel to steer left!
Two steering wheels is more efficient.
Firn
23 Pro ER
Just went and did some testing. All testing done at the exact same speeds and at the same locations, battery SOC was within a few % for each test. The numbers are the maximum amperage returned to the battery.
At 55mph
1pd drive - 306a
1pd drive w/ sport mode - 309a
2pd drive - 327a
At 75mph
1pd drive - 310a
1pd drive w/ sport mode - 317a
2pd drive - 427a (yes, four hundred)
Applying the brake pedal in 2pd drive decidedly has more deceleration and sends more energy back to the battery.
Henry Ford
At 55mph
1pd drive - 306a
2pd drive - 327a
At 75mph
1pd drive - 310a
I can buy that 2PD offers more deceleration and thus more Regen while at a higher deceleration rate. However, the distance covered to a stop will be less if the deceleration rate is higher. In other words, if compared energy added over a certain distance it will be the same.
Where it gets interesting is comparing net energy over the same distance at max performance. If max deceleration is greater in 2PD it means you will spend some amount of time using energy while in 1PD you are adding energy over the same distance. Distance is what matters, right? We measure efficiency in m/kWh not w/g.
Firn
23 Pro ER
Spot on. This was only a test to see how much current, and thus wattage, each method sends into the battery. Specifically to see if 1pd drive has higher numbers than 2pd drive since that was claimed to be the case.
potato
BC, Canada
That's the nice part about all this. We can argue until we are blue in the face. But at the end of the day, both modes are awesome with great efficiency ? Well. As great as possible when driving a brick.
