I'm out after 6 months
So it's definitely not accurate to think of capacity as a fuel tank. I knew I had to change my driving habits to take full advantage of what an EV can offer. Gotta change the way I think about SOC now too.
daveross1212
NY
'21 Tahoe Z71, 22 X5 45e, '22 F150L Lariat ER
I think if the EPA just published a "city/highway" range for EVs a lot of the "surprise" ownership stories and sensational news articles would go away. The Lighting is a 320 city / 235 highway truck and should have been sold/advertised as such. Yes the cold makes it even worse, but initial expectations for many buyers were set incorrectly and I think that's the fault of Ford and/or the EPA.
wighty
NY
Since the GOM is based on the voltage of the HVB, the range and SOC will go up.
Here's the thing, I don't think the truck is reporting the state of charge as significantly different. My truck sat overnight again, started at 86% displayed SOC and HVB temp 55F, energy to empty 75.8 kWh. This morning SOC was 85.5%, HVB temp 30F, energy to empty 70.9 kWh.
I don't think they are necessarily wrong to do it their way, but it definitely messes with our ability to use our driving efficiency and SOC to estimate our range better than the GOM.
Jim Lewis
San Antonio, TX
I think the problem is vehicle owners misinterpreting what the EPA "highway" estimate means. It's not a long trip at 70 or 75 mph or higher for hours on end. Here's a Bing ChatGPT answer to how the EPA Highway Estimate is arrived at and the average speed the EPA assumes:
According to the EPA test cycle, the average speed on the highway is 48 MPH 1. The test cycle calls for acceleration and braking across a distance of 10.26 miles, representing the surges and dips in speed that might be experienced during a typical highway run 2.
Numbers 1 and 2 are links to the articles on which the summary is based. In figuring the combined city/highway driving range, the EPA weights the city driving range/mpg at 55% and the highway driving at 45%. So, if your 100% 70 or 80 mph, you're not going to come close to the EPA combined range or even the highway range. You can customize the % highway/%city with the following EPA calculator but it's still not going to adequately account for mostly very high speed driving: Personalize (fueleconomy.gov)
I can get 2.4 to 2.5 mi/kWh driving between San Antonio and Austin, mostly 65 to 70 mph, for an estimated range of around 280 mi in my Lariat ER at 60 to 80 degrees F and low wind speed. I'm on BlueCruise most of the way, accelerate and decelerate very gently, and usually travel 3 to 4 car lengths behind a vehicle, often an 18-wheeler. Obviously, temperature, wind speed, snow or rain, and elevation changes can make a big difference. My Austin destination is only 300 ft lower than my San Antonio start point, and I figure that costs me perhaps 0.7 kWh on the return trip, assuming, unrealistically, 100% regen recovery on the downhills.
The EPA has lots of information on its tests, but their explanations are kinda vague: Detailed Test Information (fueleconomy.gov). Here's what they say about the incorporation of higher highway speeds and more aggressive driving into their tests:
Beginning with 2008 models, three additional tests are used to adjust the city and highway estimates to account for higher speeds, air conditioning use, and colder temperatures.
The following graph under the Higher Speeds tab shows some pretty aggressive driving, but the average speed over the course was still ~48 mph.
Ford F-150 Lightning I'm out after 6 months 1704823114617
Maxx
Here's the thing, I don't think the truck is reporting the state of charge as significantly different. My truck sat overnight again, started at 86% displayed SOC and HVB temp 55F, energy to empty 75.8 kWh. This morning SOC was 85.5%, HVB temp 30F, 75.8 kWh .
I wouldn't mind seeing energy to empty instead of SOC.
Keep in mind if you accelerate hard or use high regen or anything to warm up the battery, you could get some of the energy back.
wighty
NY
Keep in mind if you accelerate hard or use high regen or anything to warm up the battery, you could get some of the difference between 75.8 kWh and 75.8 kWh back.
Yes, correct. My drive this morning (20 miles over 30 minutes) brought the pack temp up from 30F to 37F. I'm not sure how much of that was the heater or driving. The effect is probably pretty variable so tough to rely on.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
FordPass used to have a trip logging feature, but Ford could never get it to work right and scrapped it.
I dearly miss the trip log. My trip log was always spot on, until then one day, one update it just went away without warning or option to keep it…..Anyone from Ford or other, think that it is ever coming back..?? This was a great feature..!!
Ford F-150 Lightning I'm out after 6 months IMG_2979
Ford F-150 Lightning I'm out after 6 months IMG_2980
MrLoganRoss
Logan
Seattle Washington
'23.5 MachE GTPE & '24 Lightning Lariat
I have a ‘24 Lariat. I wonder how much of a difference the heat pump will make.
brewski
GA
2023 F150L Platinum
Yes
An EV isn't for everyone.
When people ask me about it, I clarify it need to fit your "mission".
City driving only? Probably a good fit.
I do about 50/50. My highway driving is 100 miles away. Good fit...for me.
I am in the south...so enter that into your equation.
EPA 'averages' don't work for anyone, with ANY vehicle, who think that it means driving 80mph for 250 miles straight...
'average' means the AVERAGE of city/highway miles ... here's the EPA statement:
" *Based on 45% highway, 55% city driving "
now, also, they don't go into ANY detail about the number of miles for each of these, OR the SPEED for each of these .... BUT, on their webpage, you can PERSONALIZE some of the data, for your own driving environment and electrical costs, to get a more 'rounded' picture of your costs, etc.
https://www.fueleconomy.gov/feg/Find.do?action=sbs&id=47821&id=46329&#tab1
