Lightning FORScan HCM spreadsheet
Any other ways to get the extended license since Forscan halted licenses due to banking rules?
You can get a free two-month extended license as many times as you need to. I got one after the rules went into effect.
Livnitup
Livnitup
2021 F150 Platinum
Yes, it counts automatically for each line at the end, but this is a little different
According to Livnitup's FORScan - 2021-24 F150 spreadsheet
734-11-01
**xx -- CRC_LOW_BYTE (CRCLOWBYTE)
734-11-01
xx** -- CRC_HIGH_BYTE (CRCHIGHBYTE)
And as I understand it, Forscan will not be able to count where **** is, it will only count at the end, where --
And in my case, I need these CRC calculations, because I want to try activate Glare Free on another car, where the HCM different and the encoding for it are different and this CRC parameter is generally contained in 734-01-04
We don't know how exactly the HCM low/high CRC is calculated but on the ICE side we've noticed 3 factors that seem to determine those:
Short bed with scales / ccd or Raptor
Long bed no scales / ccd
Long bed with scales / ccd
I'm not sure if different on the Lightning or not but from vin comparisons on the 3 factors above we've seen 3 different low/high crc values.
