Not the use of ProPower I expected… charging 12v battery
Ragman
Sorry Ford these 12v issues are becoming a PIA - truck was sitting on charger at 100% state of charge with departure set for 8:20 - at 8:24 truck alarm goes nuts with a frunk opened message in FordPass.
Truck won’t respond to anything and gives every error under sun. Now it’s completely dead…. They should not fail this “hard”.
Stuck a 25 amp booster on it, truck goes click and hop in truck powers right up. Disconnect and cycle truck again and no issues starts fine. I did not recharge the battery in 15 seconds on charger.
Change the software…. Recharge at 50% not 30% and get rid of the 48 hour logic…
This is our third truck with 12v issues.
Ford F-150 Lightning Not the use of ProPower I expected… charging 12v battery IMG_5228
Ford F-150 Lightning Not the use of ProPower I expected… charging 12v battery IMG_5229
CD4TNF
F150 Lightning ER
Weird. I left my lights on and I got a bunch of messages on FordPass letting me know the 12V was dangerously low. I was at an event so it took me over 2 hrs to get back to the truck. Basically the truck was begging me to plug it in and let it charge up the 12V. I was very nervous because the last message on FordPass basically made it sound like the 12V was done for.
Headlights were on. Got in the truck and it started just fine. No issue. I was pleasantly surprised at the number of notifications I got warning of the 12V battery drain.
Sorry your 12V is bricking itself so suddenly. It's just so different than what I experienced.
Ragman
I’m curious what year/build date is yours? That warning notice makes complete sense we’ve never gotten one 12v warning. This truck is 03/23 build date.
GoodSam
Good
occupying space
You are not charging that battery properly. You need to put the negative cable on a ground screw or the negative jump post. In fact, put both cables on the jump post.
What you are doing is bypassing the BMS and therefore the truck will not know the proper state of charge of the 12v battery, and will not maintain it properly.
MaintGrl
Marsha
El Sobrante, Ca
From another forum posting
Thank you for that reminder, I have NOT had the need to Jump my truck, and my mechanical intuition would have told me to hook up straight to the battery posts, but I guess the Truck would not know power is returning to the 12v battery...
Use the jump posts under the passenger side panel, that's what they are for.
Ragman
Yep I did catch that and used the posts after taking pictures, interestingly I put it on charger overnight and only showing 60% after 12+ hours at 5 amps. The voltage pre-boosting (dead truck) was 5 volts - immediately after was 14.8 with truck “running” then 13.6 “off w/o charger”.
Tentatively booked into Ford in two weeks to do recall and check battery. All I can find locally are H4 batteries no one stocks the small H3s…
PrimeRisk
Denver-Metro
Technonerd
Yeah, removing the passenger side panel is a PITA. I popped off the bottom half of two of the twist connectors the first time I removed it and had to go fishing for one of them in the void for 5 minutes. In reverse, it took about 5 minutes of jiggling them around to get them in the right position to put it all back together.
Not a very user friendly access. I opted to put D-Ring connectors on the correct positions after the BMS sensor to have a quick-connect solution by just pulling off the battery door. It worked perfectly to put it on a BatteryMinder while we went to Europe for 2+ weeks. Came back to a fully charged 12v and a software update.
Runaway Tractor
Yes
How is this not just actual negligence on Ford's software dev team?? There's 130kwh of power in the HVB. There's a DC-DC converter to keep the LVB charged. Battery low, hmmm, maybe now would be a good time to turn the DC-DC on and recharge?? NAH. Let's let it die and just throw senseless error codes, that sounds cool.
