One Pedal and Hold feature, truck rolls
Hank42
NY
2022 Lariat ER
One-pedal and Hold enabled driver here - have been since I got the truck new. ~28K miles later, I notice that when I come to a full stop, the truck then proceeds to roll forward a few inches after I take my foot off the brake. It feels intentional - not like slop or play, feels more like the motors (re)engage for a split second to move the truck forward before (re)applying the brakes. Almost like a "lurch". Sort of in the vein of "unintended acceleration" but I won't go so far as to label it that so as to not be alarmist.
The is especially noticeable if I come to a somewhat expedited stoppage (hard stop).
It's the electrons in your battery pack sloshing around.
Hank42
NY
2022 Lariat ER
You know what - it could be! LOL
You somehow summarized the feeling EXACTLY. Like if you ever driven a tanker trunk(oil/water etc) - that same inertial feeling of the load sloshing forward after a stop.
It's for smoother stopping.
Turn the hold off and see what happens.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I turned off the hold to allow me to creep in the garage, it also made driving feel normal. I do not move once stopped using one-pedal. If I stop more rapidly using the brakes, the truck also doesn't move once stopped.
evowner
Frank
SW Ohio
2024 Ford F150 Lightning Lariot
Retired EE
Lately I have been getting the feeling that I am still moving after I have stopped. It is like the sensation you get when riding in the back of a vehicle looking towards the back after stopping. This only happens when using one pedal. I think my brain is playing tricks on me. :crackup:
USA EV
I have the same experience as G2.
You're speaking of a change in behavior, correct? Can you reproduce it 100%? Probably worth getting checked out.
Hank42
NY
2022 Lariat ER
Definitely change in behavior. Caught my attention when the car in front of me braked hard at a red light and I did the same. Let off the brake, and felt the truck move forward a few inches - as if it were in creep mode. Was able to repeat that a few times.
I read some of the suggestions above like checking the auto-hold settings etc, Possibly one of those got turned on or off, (there are only two! LOL) - so I'll have to do some experimenting in each mode.
The fun thing is that it is hard to tell a mechanical problem from a possible software -update related issue - I wish I could "CTRL-Z" and undo the last update to see if the behavior is the same. Sadly, sounds like a trip to the service center - my first for a strange issue like this, and glad I posted because that "sloshing" feeling describes it perfectly, and is something I can convey to the service team - way better than my explanation :) So thanks to everyone who posted.
VTbuckeye
Joseph
Vermont
Hopefully the service team is very familiar with EVs to know what feels right and what is abnormal. I feel like this is the perfect opportunity to gaslight the EV driver. "This is how they all behave" be e careful that they don't use any Jedi mind tricks.... These aren't the droids you're looking for..Move along "
Hank42
NY
2022 Lariat ER
Yeah - LOL - I hear ya - I'll be mindful - I've got 28K racked up on this truck and over 200K on other EV's - I'll _START_ with that upfront as an offensive defense :)
Grumpy2
23 F150 Pro SR
It must be normal, I unintentionally tested your issue.
Using one pedal I approached a car stopped at a light, and I misjudged my speed slightly and just touched the brake pedal and received a 99% when I stopped. When the light changed, the car slowly moved and I released the brake but didn't touched the go pedal since he was still close. The truck advanced a few inches before the brakes reengaged.
It must be something like 3" ? but it was clearly a movement. Not a big deal, but I see where it would be a concern if I had stopped close to the other driver.
It must be normal.
Hank42
NY
2022 Lariat ER
It must be normal.
Well, that sounds like the behavior. Why do I suck at describing things lately? Anyway you nailed it.
Is it "Normal"? I don't think so.
Is it "New"? Yeah, this is something new in the past few months for sure - thought it might be cold/winter related, but did not have this behavior before the fall for sure.
