SmoothJ
New Jersey
2022 F150 Lightning
If you have a Lariat+, you can load your profile by pressing the memory recall button associated with your profile. I instinctively do that when remote starting both our Lightning and Mach-E because Ford can't figure out how to fix getting the Guest profile after a remote start.
I had the same issue. However once you tie the key used (key fob) and the cell phone used (Add Phone under user profile) and PaaK, it will recognize who started the truck.
Ford Senior Master
Pell City, Alabama
Service Manager
Since I'm stuck on 3.5.2 since Sept 7 could someone tell me if 4.1.1 fixes stupid crap like the image below. Or is that corrected with the DTE update?
Ford F-150 Lightning Power Up-4.1.1 OTA software update released Screenshot_20230115-132054_FordPass
Gimme_my_MME
If the issue you are talking about is the distance not resetting, the fix is not in this update. It was bundled with some other stuff that got delayed
When I remote start and get in, it doesn't automatically load my profile. Same with my wife's Mach-E. Doesn't matter whose key or phone we have on us. It automatically goes to Guest. That points to a software problem.
It did this randomly on my 2021 ICE truck too.
SmoothJ
New Jersey
2022 F150 Lightning
Yes, and I don't doubt it. However I had the same issue, and in order for me to "fix" it, I had to be sure to add my phone to my profile, and my key. I thought by doing the PaaK would add it, but it didn't and I had to go though more steps.
I've got my phone tied to my profile and when remote starting and getting in to drive I've not ever had the truck fail to have my profile set. I use the exit settings too, so I know when I last exited the truck the seat slides back and the wheel moves up and out of the way. I get in and press start, everything slides back into place for my profile.
Is your phone close enough that it's connected through Bluetooth? That is the common thing with mine.
If my phone is connected to the truck with Bluetooth and I start it, like I do in the morning before my commute, my profile loads. When leave work and am in the plant, far away from the truck, the truck has the Guest profile loaded up and I have to hit the memory button on the door to load it.
SmoothJ
New Jersey
2022 F150 Lightning
When I remote start mine, I am not in BT range. In the AM, if I noticed it has not pre-con, I normally ask Alexa to start the vehicle.
In both case I would get the guest profile till I made sure the key fob and my phone were tied to the the car (again not just PaaK).
FinsNBolts
Clearwater, FL
2022 F-150 Lightning Lariat
I had a profile issue on remote start when I first got the truck. Once I delinked the fob and RE added it, it seemed to fix the problem. I remote start every day and I have not had the guest profile load since I RE-linked the fob.
Alan168
Alan
Massachusetts
2022 Lightning Platinum, Rapid Red Metallic
I still have not been able to get the updates so I was thinking of disconnecting/charging the LVB. How long does it need to be disconnected? When the LVB is disconnected and then reconnected, does it reset your personal choices such as radio stations, or other personalized settings? Does it impact the FordPass or Charge station apps? Is there anything you need to reset or re-install?
Thanks!
Those are the buttons I was referring to.
Used the seat memory button today after a remote --- remote start session, it worked perfectly, no fumbling through the menus to pick my profile!!
Reactions: GDN
bewbie
NYC
Speaking of Bluetooth, does everyone phone show 2 bluetooth connections for the truck or just mine?
I get at least 2 - thought I had seen a third one at one time. There is at least one I believe for proximity, PAAK, etc and then another for Infotainment/phone/music.
One is a name I don't control and one is to the Name that I set in the truck setup.
