Powertrain Malfunction/ Reduced Power
Harvard, MA
2023 Ford Lightning Lariat
For my spreadsheet tracking the PM/RP, battery cell/module, or related failures (in my signature below) would you be so kind as to let me know, or post here, your build date (mo,yr top of drivers door b-pilar sticker), mileage, model/year, ER/SR battery? Trying to see if Ford is getting better at having SK On manufacture batteries (cells in modules) that do not fail. Thank you!
@solastobann @AkaKreisler @riceilove @Lightning Bronson @Iroc34a @vvgogh @jcarterpdx @K-Loader @dancwilliams @derelict @mpatel1101 @skinner @woodrax @HRCC @Christopher Ryan @Vito @Freddyfresh @Airboss @gapsd @ZSC100 @sgreeley @Zprime29 @Mwillselectric @LVice @Wonko @Psmith7279 @Big J’s 23 Lightning @mjdonat @dfowkes @burley4 @ivan256 @drewfaulk @AmandaB
Build Date: 11/22
Mileage: 21721
Model: 2023 Lariat
Battery: ER
HV Module replaced in July 2023 at 4153 mi - Campaign 23H01 recall; no issues since
chachalacosp
Chico
2024 F150 Lightning
Not sure if I need to be on your list or not since my truck hasn't been properly diagnosed or fixed yet. I got 'powertrain malfunction reduced power' message when trying to DC fast charge and I still can't charge. My issue may be something other than the battery pack but who knows, they have mis diagnosed it 2 times already. Here are my stats just in case.
24 Flash
Battery ER
build date 1/24
issue started at 2,900 miles
riceilove
EC
Denver, CO
2023 F150 Lightning Lariat ER
My b - I requested access before realizing to just post here lol.
Build Date: Unknown - will add when I find out after getting my truck back.. whenever that is
Mileage: 8217
Model: 2023 Lariat
Battery: ER
jcarterpdx
JC
Portland, OR
2022 Ford Lightning Lariat ER
09/22
23k miles
2022 Lariat
ER
mgmessner89
Matt
Phoenix
2023 XLT Lightning SR
Add me to the list. 2023 XLT SR power reduced to 53 and charging faults. Dropping off at Peoria Ford here in AZ tomorrow. Been on software update 10.1.1 for a month so no new updates that would have caused this.
Build Date 10/23, purchased 7/24. 6900 miles.
Just spoke with my service rep, the battery array is on back order (sigh). He didn't have the proper part ID to give me but he said they are on backorder until early Feb to Detroit and will be shipped to AZ then so probably will be in my loaner for 2 weeks which I pick up tomorrow. My dealer told me the part doesn’t come from Ford directly but a third party so they have no exact eta. Just guesses
Wonko
Erick
Atlanta
2023 F-150 Lightning Platinum
Just got my Lightning back from having the (second) recently replaced module rebalanced. The dealer that replaced it couldn’t be bothered, so the new place had to tear the pack down again and hook it to the XMB. They had to drill out and re-tap 2 HVB cover bolts that the first dealer apparently over torqued.
Anyway…
Build date 8/23
1/22/24 - Wrench Light - Reduced Power - Failed to Charge - Mileage of 1st failure (module 3) - 5,991
11/22/24 - Wrench Light - Reduced Power - Failed to Charge - Mileage of 2nd failure(module 5) - 10,862
Platinum trim (LR Battery)
After module 5 was replaced, I took it to another dealer because of failure to charge to 100%. They found a faulty coolant heater module that was throwing over-temp codes. I’m not 100% convinced the failed heater module isn’t the cause of the battery module unstable voltage. Others with these symptoms have stated their repair was only a coolant diverter valve, making me think these modules are very sensitive to temp and may either fail or think they failed when the temp gets out of range.
dancwilliams
Dan
Louisiana, USA
2023 Lightning XLT ER
Build Date: 10/23
Mileage: 13,484
Model: 2023 Lightning XLT
Battery: ER
mgmessner89
Matt
Phoenix
Just picked up my loaner. Array 65 in module 7 is going to be replaced. No ETA for when the dealership will receive it.
Build 12/23
XLT SR
6900 miles
vvgogh
Colorado
'23 F-150 Lightning ER
Day 1, Tues 7 Jan. vehicle dropped off - no loaner offered
Day 4, Fri 10 Jan. Technician looks at vehicle sees anomalous 30 mV voltage delta of suspect cells in module 3. Service dept requests warranty replacement module from Ford
Day 8, Tues 14 Jan. Ford approves warranty replacement module order
Day 11, Fri 17 Jan. Service department offers loaner gasoline vehicle, no fuel reimbursement offered
Day 18, Fri 24 Jan. Replacement battery module arrives
Day 23, Wed 29 Jan. (Projected) Service department expected completion of repair as of day 18
@Ford Motor Company - is this the experience you want your customers to have, 23 days without their new, still safely drivable vehicle? You could cut 22 days off this process by contacting customers with remotely validated anomalous voltages, order the replacement module, schedule the service with your approved service department once battery module arrives, and complete the warranty repair in a single day.
muels7
22 F150 Lightning Lariat
Got this message yesterday when I went to leave, and now I get a charging fault as well. Dealers in my area are backed up..... great.
Can I drive it still for a day or 2? Is that safe?
Gimme_my_MME
If you are able to drive the vehicle it is safe to drive. If it was not safe, it would not let you.
Whether you feel comfortable is a different question
Piquette
Trent
New Hampshire
2022 Lightning Lariat
Not recommended. You cannot recharge it so you are limited to driving the distance you currently have. Also, the lower the charge when the mechanic gets to it, the more difficult it is to rebalance the modules if one has to be changed. Just get it to a dealer who will quickly diagnose it and put you in a loaner if it is a faulty battery module.
muels7
Called 4 dealers within 20 miles. Only 1 could get me in, and not until tomorrow. The rest said they are backed up 2 weeks+ to even look at it. None will provide me a loaner until Ford approves it under warranty....which won't happen until they can diagnose it.
